What are Your thoughts on Nitrous????
Old Mar 7, 2003 | 11:32 PM
XxDemonxX's Avatar
Default What are Your thoughts on Nitrous????
i was just wondering what you all thought about it.
most of yall think its cheating. But i want to hear from some people with good experience with it. Is it true if you MAKE SURE everytime you squeeze you hold it LESS the 2 or 3 seconds it wont hurt ur car? What is the worst that could happen if you use it properly....by that i mean holding less then 3 seconds everytime you use it?????????
please list pros and cons about nitrous
thanks
Old Mar 7, 2003 | 11:41 PM
tnbigdawg's Avatar
Default Re: What are Your thoughts on Nitrous???? (XxDemonxX)
Nitrous makes me laugh
Anyways, IMO nitrous is fun when hooked up right. But one misfire, bad timing, or air/fuel ratio and say goodbye to your engine
Old Mar 7, 2003 | 11:48 PM
TimoneX's Avatar
New User
Default Re: What are Your thoughts on Nitrous???? (tnbigdawg)
Nitrous is a gas when used properly. Just make sure you're tuned for it. There'll still likely be some increased wear from it's use due to the higher heat levels.
Old Mar 7, 2003 | 11:53 PM
XxDemonxX's Avatar
Default Re: What are Your thoughts on Nitrous???? (TimoneX)
any recomendations on what someone should do before spraying....engine maintnence wise?????? also on proper tuning?
Old Mar 8, 2003 | 12:03 AM
TimoneX's Avatar
New User
Depends on the miles on your car and how much giggle gas you intend to introduce, but in general setting your timing back to stock or slightly retarded, colder plugs, and a slightly richer A/F ratio are the tools used.
Old Mar 8, 2003 | 12:16 AM
XxDemonxX's Avatar
if that is done and i dont get Nitrous happy my car should be fine?
its has 94k.....98 ex with i/e
[Modified by XxDemonxX, 9:16 AM 3/8/2003]
Old Mar 8, 2003 | 02:23 AM
T3's Avatar
T3
Sucks...Nos
I have never ran it but I have some friends that do.I give props on how much it helps but I dont like.
Old Mar 8, 2003 | 06:14 AM
preluder's Avatar
Default Re: What are Your thoughts on Nitrous???? (T3)
my reply on the situation make sure that car s tuned right dont do it yourself have a proffesional on cars i mean a real one. dont halfassed it or youll be sorry in the end uhhhm make sure you get a racing engine to withstand it do something to boost your fuel cause if the fuel aint there the power wont be there either which=fucked.
Old Mar 8, 2003 | 07:17 AM
torr's Avatar
Default Re: What are Your thoughts on Nitrous???? (preluder)
nos is safe. the brand i used was nos by holley. i sprayed a 70 shot on a b16 for 2yrs. constantly. i raced in my town every other week and i ocassionally street raced also for 2 yrs. at first i didn't no **** about it. my friend got one so i thought it'll be cool to get one too. at first it was just a 40 shot, so i really didn't change anything, but after a while i wanted to increase my horespower. i did my research on nos and basically you need a performance ignition, colder plugs ngk7bre, stock fuel pump is ok. but look into getting a performance one. and most importantly, read and understand the instructions, and have someone competent enough to install it. is nos cheating? hell no. horsepower is horsepower. just don't do like i did and depend on nos everytime i raced. i felt my car wasn't all that unless i was spraying. it's addictive and expensive.
Old Mar 8, 2003 | 10:43 AM
MikeMAN's Avatar
whoever told you 2 or 3 seconds is an idiot. you can use it for 15 seconds safely.
pros:
if you know how to be responsible in the use of it, it can be a inexpensive way to go fast
cons:
if you hit the revlimiter you might be in trouble (100% nitrous + spark=boom) but you can get an RPM window switch for this
i ran a 75shot every other day on my stock b16. was quite fun !!
mike
Old Mar 8, 2003 | 01:12 PM
1SlowB16EF's Avatar
NAWWWWSSSS! its great when tuned properly and most importantly used by some one who knows what they are doing!
Old Mar 8, 2003 | 03:37 PM
dc2specR
Guest
Posts: n/a
Default Re: What are Your thoughts on Nitrous???? (1SlowB16EF)
Quote:
Depends on the miles on your car and how much giggle gas you intend to introduce, but in general setting your timing back to stock or slightly retarded, colder plugs, and a slightly richer A/F ratio are the tools used!
__________________________________________________ ______________
Exactly! It's alot of fun too! I am selling a Zex kit that is in flawless condition- only two bottles run through it. If you have a gsr, I have an AEM cold air that is predrilled for the line and all ready to go with this kit! Let me know if you're interested. Ask around, the Zex kit is the safest kit on the market!
Email me at JDMspecR@hotmail.com and make a fair offer
Old Mar 8, 2003 | 04:11 PM
dfoxengr's Avatar
i the gas for street NA...and will be puttin on the bottle soon for that purpose only
Old Mar 8, 2003 | 06:48 PM
9200RPM's Avatar
Default Re: What are Your thoughts on Nitrous???? (MikeMAN)
pros:
cons:
mike
did you ever run it at the track....i plan on starting out with the same setup...
Old Mar 9, 2003 | 08:57 AM
T.J.'s Avatar
retard your timing, check your fuel, i would recomend going with a 1 to 2 stage colder plug depending how much your spraying , and if your running a wet system especially direct make sure all your fuel lines are tightend down real good.
cliff666
Dec 8, 2003 12:27 PM
mattduskater
Oct 4, 2003 06:59 PM
Sassafrass
Jun 5, 2003 10:54 AM
newtegowner
Oct 30, 2001 08:07 AM
