dump pipe testimonial
Old Mar 6, 2003 | 11:53 AM
queez's Avatar
Default dump pipe testimonial
by adding a wastgate dumppipe, will this increase hp?? or just for some heat dissipation?? anyone with experiecne
Old Mar 6, 2003 | 11:56 AM
PM-Performance's Avatar
Default Re: dump pipe testimonial (queez)
some say it will help you gain a few ponies if you dump it back into your exhaust, but i dunno if thats true, there are alot of specualitions on that and how far downt he exhuast you should route it .
i just run a reg dumptube, routes stright down
Old Mar 6, 2003 | 11:59 AM
Smashback's Avatar
Default Re: dump pipe testimonial (itr206)
That's backwards...most people say you LOSE HP by going back into the exhaust.
I think as long as you use your head when designing it won't be a big deal.
Old Mar 6, 2003 | 12:12 PM
zojirushi's Avatar
i don't recommend running without a dump tube... i made that mistake and now i have no a/c
Old Mar 6, 2003 | 12:16 PM
BoostedH23a1's Avatar
Default Re: dump pipe testimonial (zojirushi)
depends on your setup.. on my friends its blowing on the downpipe and on the ground so it doesnt matter.. he has so much room under the hood its redicuous
Old Mar 6, 2003 | 01:15 PM
turbologist's Avatar
Running an open dumptube will get u a few HP...It also get a little louder when the WG opens...Just make sure that its routed towards the ground and comes down as far as possible or better yet bring it down then divert it towards the back of ur car parallel to ur exhaust....
Old Mar 6, 2003 | 02:49 PM
Diego Boost's Avatar
Default Re: dump pipe testimonial (Turbologist)
Yeah, I need to re-route my dump tube, when the WG opens I get major exhaust stink inside the car.
092eg6
Jan 11, 2011 08:53 PM
JBLAZE622
Apr 29, 2010 04:30 PM
gldndrgn14
Apr 19, 2008 09:23 PM
the.hamburglar
Jun 29, 2005 11:04 PM
InfamousRS
Jan 22, 2002 10:07 AM
