muffler question
i know this isn't really a tech question or anything, but i'm just curious if an OEM muffler will be alright with a turbo kit? the reason i ask is because my friend is going to borrow my OEM muffler tomorrow for legal purposes and he has a GReddy turbo kit. will my muffler come back with a rattle? or should it be able to withstand the excess pressure of a turbo? just curious, because i might need to use it later on myself.
how about if he uses my whole OEM exhaust system? will the turbo completly fry my system?
well from what i understand is that with the stock piping and stock muffler, your power will suck as there isnt big enough piping to flow all of the exhaust gases through, why not go with something 2.5 to 3"??
On a side note i have heard of people basically blowing the welds on an exhaust system from to much pressure, not sure if this will be the case.
yeah it should just be for a short time as he just needs to get it smogged. so it'll come back the way it was if he only uses it for a trip to the smog station, correct? thanks
Does your friend use a cat with his current set up? You understand that a cat back exhaust system doesn't affect emmissions? If he has no cat, then using your system will work, but as mentioned above, he better not get on it too much, or he could pop the muffler off the piping
yeah i understand that, but i believe he wants to use it for the reason that he has to go to smog ref because he got a fix-it ticket a while back. so i guess he just wants to be extra safe about it. i also believe he is running on his stock cat right now. thanks
so simple
Jan 29, 2008 11:54 PM
DRKSol
Aug 29, 2003 07:32 AM
YumYumRoLL
Dec 20, 2001 11:04 AM
