camshaft question!!!
Old Mar 6, 2003 | 02:00 AM
90da4dr's Avatar
Loved
Default camshaft question!!!
when looking at the specs for different camshafts, what does gross lift or duaration exactly mean? (does the higher the duration mean more hp and the higher the lift = more torque).
Old Mar 6, 2003 | 11:42 AM
joe_bocc's Avatar
Default Re: camshaft question!!! (89civ)
Lift refers to the amount of lift the valves. Its measured in millimeteres.
Duration refers to the amount of time the valves spend open. Its measured in degrees of crankshaft rotation.
Generally, higher light, longer duration makes more power because more air cam flow past the valve.
Old Mar 6, 2003 | 12:09 PM
Spade's Avatar
Default Re: camshaft question!!! (joe_bocc)
The highest point of lift
Durantion refers to the amount of degrees on the cam shaft there is some sort of lift. I.E. 272 degree cams means that for 272 degrees around the 360 degrees of the camshaft there is some sort of lobe
Generally, higher light, longer duration makes more power because more air can flow past the valve.
Old Mar 6, 2003 | 12:16 PM
joe_bocc's Avatar
Default Re: camshaft question!!! (Spade)
Even I've learned something from this post.
sibluecrx
Feb 3, 2007 02:21 PM
VTECcnIT
Nov 10, 2005 05:46 AM
matata55
Dec 23, 2004 09:54 PM
216.226.142.95:27016
Jun 28, 2003 01:41 AM
Cow
Jun 26, 2002 04:12 PM
