will valve adjustment affect performance?
Old Nov 8, 2005 | 09:15 PM
VTECcnIT's Avatar
Default will valve adjustment affect performance?
does valve performance effect performance at all? does it imporve performancE?
Old Nov 8, 2005 | 10:05 PM
mmuller's Avatar
Mad Scientist
Default Re: will valve adjustment affect performance? (VTECcnIT)
not really; but in theory, yeah
Old Nov 8, 2005 | 11:54 PM
intekragsr's Avatar
Default Re: will valve adjustment affect performance? (mmuller)
actually it does affect performance in a big way. Throttle response and gas milage are improved. At any RPM your power (exhaust and compression) will be leaking out of your valves.
Before I adjusted the lash, it would take me 18 gallons to drive from Los Angeles to San Francisco. Now it takes me 14.5-15. And these results were consistant before and after.
If u can understand how an engine works, its easy to picture how valves out of spec would diminish performance.
Old Nov 8, 2005 | 11:55 PM
intekragsr's Avatar
Default Re: will valve adjustment affect performance? (intekragsr)
do you know how to adjust valves?
Old Nov 9, 2005 | 12:23 AM
VTECcnIT's Avatar
no but the shop just did it and i think they adjust it too tight
Old Nov 9, 2005 | 05:47 AM
mmuller's Avatar
Mad Scientist
the only way combustion gases will scape the chamber is ifthe valves are adjusted too tight...wich does not happen unless you *** up adjusting them
Changing valve clearances is like changing the ramp/lift of a cam. Its just that its very minor to notice unless an extreme case.
Old Nov 9, 2005 | 07:33 AM
Rikter's Avatar
It isin't so much that it will gain you performance... it will just regain what you're currently loosing due to un-adjusted valves.
-Rik
Old Nov 9, 2005 | 07:50 AM
PLAGUED_DB7's Avatar
Default Re: (Rikter)
not only that, but think about the blow by from valve leakage due to not sealing..When I adjusted a friends valves, he stopped burning some oil too.
his intake valves would suck oil in and his exhaust valves would blow oil out...
not that I did that he said the car has a better sound under the hood and out the exhaust..Minor things like being .002 out of spec can also cause some wear on the rocker arms, and cost you in the long run...
Old Nov 9, 2005 | 03:55 PM
mmuller's Avatar
Mad Scientist
Default Re: (PLAGUED_DB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLAGUED_DB7 &raquo;</TD></TR><TR><TD CLASS="quote">not only that, but think about the blow by from valve leakage due to not sealing..When I adjusted a friends valves, he stopped burning some oil too.
im sorry to be blunt, no offense; but that statement makes no sense at all.
And once again, when you adjust and adjustment is needed 100% of the time valves are loose. loose valves will not cause the valve not to seal...
If the valves are adjusted OVERLY tight; then the cam constantly pushes on the valves thus keeping them from sealing. But if it gets to that you have other problems to worry about...like worn rockers and worn/broken cams..
Old Nov 9, 2005 | 04:36 PM
JDM DC2 y0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECcnIT &raquo;</TD></TR><TR><TD CLASS="quote">does valve performance effect performance at all? does it imporve performancE?</TD></TR></TABLE>
doing a valve adjustment will make your valves more quiet without the ticking, better performance and also better gas milage.
Old Nov 10, 2005 | 04:24 AM
s2kkid's Avatar
the first time I adjusted my valces, i did them too tight and it ran like ****.
so yes, it can effec performance if done wrong
Old Nov 10, 2005 | 05:43 AM
Baron55's Avatar
how often the vavles need to be adjusted?
Old Nov 10, 2005 | 05:46 AM
mmuller's Avatar
Mad Scientist
Default Re: (Baron55)
15k by manual im pretty sure; but they might need to be adjusted more often
VTECcnIT
Nov 9, 2005 05:43 AM
GSRVTEC1
Oct 31, 2005 01:19 PM
sneakychaos
Sep 9, 2002 05:48 PM
itrsport.com
Sep 24, 2001 08:27 PM
