Hood wont close w/ top fitting in wastegate, what can i do.
Old Mar 5, 2003 | 05:22 PM
BoostedGSRBubble's Avatar
Default Hood wont close w/ top fitting in wastegate, what can i do.
I cut the nut part of the fitting in 1/2 and even cut a hole in the fiberglass frame of my hood. Still wont close, even w/ the hood latch all the way @ the top. What can i do.
Old Mar 5, 2003 | 05:37 PM
Tofurky's Avatar
Default Re: Hood wont close w/ top fitting in wastegate, what can i do. (BoostedGSRBubble)
get an elbow for the wastegate.
which manifold ar eyou using? and which wastegate? tial 35mm?
Old Mar 5, 2003 | 05:41 PM
Default Re: Hood wont close w/ top fitting in wastegate, what can i do. (Ruckus138)
I have an earls elbow and it still wont close. Its a tial 35mm and inline pro mani. Im considering using some washers to lower my motor. I dunno what else to do.
Old Mar 5, 2003 | 05:43 PM
Oh you mean to move the wg on its side. Anybody make those?
Old Mar 5, 2003 | 05:47 PM
boostaholic's Avatar
If you have a good welder you can make one out of a 45 degree bend and two flanges. I think Revhard and or Inlinepro makes a wastegate elbow. Also if you're not running a boost controller, you can just take that top fitting off of the wastegate.
Old Mar 5, 2003 | 05:51 PM
Default Re: Hood wont close w/ top fitting in wastegate, what can i do. (boostaholic)
Thanks ill call them tomorrow. The reason I need the fitting on top is cus i have a trust MBC i will need to use.
Old Mar 5, 2003 | 05:52 PM
BoostedH23a1's Avatar
drag makes them.. my friend has one on his del sol.
Old Mar 5, 2003 | 05:56 PM
Tofurky's Avatar
Default Re: Hood wont close w/ top fitting in wastegate, what can i do. (BoostedH23a1)
yeah i should've gotten one of those. now it's a little late though... already poked a giant dent in my hood. meh.
Old Mar 5, 2003 | 06:10 PM
That means im gonna need a new dumptube, fock! Im about to put my stock hood back on and just dent it baby!
Old Mar 5, 2003 | 06:17 PM
B20-T's Avatar
i am goin to cut my hood support bar part it look like it might clear if i cut it
Old Mar 5, 2003 | 06:22 PM
abraunb16's Avatar
New User
Default Re: Hood wont close w/ top fitting in wastegate, what can i do. (B20-T)
I just used a small brass 90 degree on my Tial and it cleared just enough. You can pick these pieces up at local hardware stores or Home Depot. Good luck, Allen
Old Mar 5, 2003 | 06:26 PM
Default Re: Hood wont close w/ top fitting in wastegate, what can i do. (abraunb16)
Ill have to try that first.
Old Mar 5, 2003 | 06:27 PM
MiraiZ's Avatar
I would try raising the height of the springs or the dampers by the latch a bit...
Old Mar 5, 2003 | 07:45 PM
Charles B.'s Avatar
hit up HT member iC Roger he has some with flanges on each end for like $30. i think they are made for DRAG manifolds but it may work. hth.
LSej1
Apr 22, 2010 05:35 AM
mra4886
Jul 20, 2007 05:44 AM
BobGnarly
Aug 9, 2004 11:13 AM
Nextelbuddy
Mar 26, 2004 01:26 PM
