Wierd Idle.....
Old Mar 5, 2003 | 04:52 PM
MeanGreenEG9's Avatar
Default Wierd Idle.....
Need some help.. I recently tightend my throttle cable because there was a bit too much lag... I think by doing so my idle is too high.. The odd thing is if I'm just crusing and come to a complete stop, the idle is normal where it should be around 600-700.. but if I am stuck in traffic or in a parking lot just slightly nudging my car along ever so slowly and then come to a complete stop, sometimes my car will idle at around 1100-1500... If I press the gas it revs up and then revs back down to normal idle around 6-7 hundred.. now sometimes even when i tap the gas it doesn't go back down to normal idle... anyone have idea on why this is happening? I guess it could be the throttle cable is too tite but ift hats the case then why wouldnt it always idle this high? TIA.
Old Mar 5, 2003 | 05:10 PM
sslude's Avatar
Default Re: Wierd Idle..... (B16aEJ)
i think it's your throttle calbe, but i dont have an explanation about why it goes back down
Old Mar 5, 2003 | 06:08 PM
Default Re: Wierd Idle..... (sslude)
anyone else?
Old Mar 6, 2003 | 09:19 PM
phantoman's Avatar
fresh idle: it is located on the bottom of the throttle body. do u have htat?
if not u may need it. if not u can manualy adjust the idle by turning the screw on the thorttle body.
Arthas
Mar 14, 2010 09:08 PM
itzyaboyzeem03
Sep 30, 2009 04:11 PM
90Rexx
Jul 2, 2008 08:53 AM
emooheo
Mar 23, 2007 02:34 PM
350z-tech
Nov 10, 2001 10:46 PM
