HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT?
Old Mar 5, 2003 | 01:08 PM
yaya's Avatar
Default HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT?
thanks, this forumn is better for tech than the tech section anyways
like the topic says....im going to be adjusting my vavle clearances, thought it would be easy till i looked how to access my crank pully nut.....its freakin burried!
how do you guys do it?
Old Mar 5, 2003 | 01:10 PM
YEE*MagicEK20kombobomber's Avatar
* B A N N E D *
Default Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (yaya)
take off ur front driverside tire... and then take off that black guard ****...i think...
Old Mar 5, 2003 | 01:15 PM
95IntegraGSRAZ's Avatar
Default Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (eeJayeiGht)
I took off the plastic to get at it, and used a 3" extention bar on a ratchet to turn it, worked great for me.
Old Mar 5, 2003 | 01:24 PM
yaya's Avatar
Default Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (civicvteckid)
ok cool, i thought there was another option besides removing the wheel
thats why i asked
thanks!
eg forumn rules y0
Old Mar 5, 2003 | 01:27 PM
kmf0211's Avatar
ok Newbie question time:
What exactly does this do?
lol sorry for being a newbiee
Old Mar 5, 2003 | 01:31 PM
yaya's Avatar
Default Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (Si.Hatch.92)
it rotates your crank...so you can adjust each valve for each cylinder at TDC (top dead center)
Old Mar 5, 2003 | 02:01 PM
blufke's Avatar
my fender lining on both my hondas had the hole to put a socket through to get at it.
Old Mar 5, 2003 | 02:09 PM
Foozball26's Avatar
Default Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (blufke)
just turn the wheel all the way out and you should be able to get at it
Kid1320's Avatar
thats why i asked
thanks!
eg forumn rules y0
you can turn your wheel all the way to the left
Old Mar 5, 2003 | 02:13 PM
kikicamacho's Avatar
Default Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (Kid1320)
I did that, you need like 2 or 3 long extensions.
Old Mar 5, 2003 | 04:47 PM
owen_the_soyboy's Avatar
Default Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (jcamacho)
I use a deep socket on the end of one 12" extension,
reaches in there fine...
but the socket always falls off the extension when I pull it back out ~!
Old Mar 5, 2003 | 05:00 PM
Finest's Avatar
ROFL! Removing the wheel makes life MUCH easier! You can get better leverage, instead of using 3-4 extensions and getting black rubber marks on your forearm. LOL!
PatrickGSR94
Nov 25, 2008 09:10 AM
DC4 Rasta
Aug 27, 2007 12:50 PM
Diversion
Aug 13, 2006 06:09 PM
neogenesis2004
Mar 24, 2004 02:16 PM
jond
Apr 2, 2002 03:57 AM
