HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT?
thanks, this forumn is better for tech than the tech section anyways
like the topic says....im going to be adjusting my vavle clearances, thought it would be easy till i looked how to access my crank pully nut.....its freakin burried!
how do you guys do it?
* B A N N E D *
Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (yaya)
take off ur front driverside tire... and then take off that black guard ****...i think...
Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (eeJayeiGht)
I took off the plastic to get at it, and used a 3" extention bar on a ratchet to turn it, worked great for me.
Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (civicvteckid)
ok cool, i thought there was another option besides removing the wheel
thats why i asked
thanks!
eg forumn rules y0
thats why i asked
thanks!
eg forumn rules y0
Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (Si.Hatch.92)
it rotates your crank...so you can adjust each valve for each cylinder at TDC (top dead center)
my fender lining on both my hondas had the hole to put a socket through to get at it.
thats why i asked
thanks!
eg forumn rules y0
thats why i asked
thanks!
eg forumn rules y0
Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (Kid1320)
you can turn your wheel all the way to the left
Re: HOW the HELL do I GET a SOCKET WRENCH to the CRANK pulley NUT? (jcamacho)
I use a deep socket on the end of one 12" extension,
reaches in there fine...
but the socket always falls off the extension when I pull it back out ~!
Diversion
08-13-2006 06:09 PM
