Changed primary O2 sensor after CEL code, but it still stays on? (Did a Search)
Old Mar 5, 2003 | 05:34 AM
Milano97's Avatar
Default Changed primary O2 sensor after CEL code, but it still stays on? (Did a Search)
Hey,
As the topic says, that's what happended...I had a CEL for the primary O2 Sensor (the one in the header). So I changed it to a new one, and the CEL still comes on, same thing Code 1, O2 Sensor...I did a search and got results that suggested on changing the battery? I don't know if that's really anything...and checking the wires and wiring harnesses, etc...I did all of those except change the battery and I tried resetting the ECU like 5 times and nothing works...any other suggestions? Thanks.
Old Mar 5, 2003 | 05:56 AM
oldbeefcake's Avatar
Default Re: Changed primary O2 sensor after CEL code, but it still stays on? (Milano97)
maybe you got an another bad O2. They are very easily damaged during installation. Did you buy it used or new?
Old Apr 5, 2004 | 11:43 AM
gotsmokedright2's Avatar
Default Re: Changed primary O2 sensor after CEL code, but it still stays on? (oldbeefcake)
so what happened? im having the same problem.
Old Apr 5, 2004 | 11:48 AM
VX_SOHC's Avatar
Default Re: Changed primary O2 sensor after CEL code, but it still stays on? (gotsmokedright2)
https://honda-tech.com/zerothread?id=798020
not sure if that will help
civic=goodgasmileage
Honda Civic (2001 - 2005)
Sep 19, 2009 03:25 PM
LsPower
Dec 3, 2002 08:56 AM
FLIPboi
Sep 24, 2002 07:34 PM
