d15 block z6 head p28 ecu?q's
is this as easy as getting new head studs and a y8 head gasket and wiring vtec? do i need anything else? i thought i heard of a oil pressure switch in the block of the d16 does my d15 have this or do i need to transplant? any one done this pls respond... this weekend hopefully.
Found this, if it's what you mean:
on D15B7 the jet is in the block, must remove for mini-me. On the later 96+ setups, the "jets" are in the head if they needed it.
d15b7 block and d16z6 head? and a p28 ecu? im doing the same thing on my 95 dx hb. but i will be boosting it.
u gotta remove the block oil jet otherwise there will be too much oil pressure and vtec wont work properly (or something). this is from what ive read. i have yet to actually do it. as for wiring, u need to wire the vtec pressure switch (D6) and the vtec solenoid (A4). d6 and a4 are the wiring spots on the ecu. theres an image around that can show u... i dont have the link to it tho... good luck... hope i was of some help.
92_VX_EG
May 12, 2007 06:31 AM
