need help from those who have installed aftermarket power door locks in a civic
Old Mar 4, 2003 | 03:31 PM
hatchdrvr's Avatar
Default need help from those who have installed aftermarket power door locks in a civic
I am in th eprocess of installing aftermarket power door lock solenoids in my '95 civic. All of the wiring has been run, but I need to mount the solenoids and there seems to be no place to put them that they aren't obstructed by the door panel or window mechanism. Where in the hell cna I put these things so they will work properly? Please, any help is appreciated.TIA
Old Mar 6, 2003 | 05:37 PM
Bigjon
Guest
Posts: n/a
Default Re: need help from those who have installed aftermarket power door locks in a civic (hatchdrvr)
I am about ot do the same thing in my 93 civic. If you figure it out before i do then let me know
Old Mar 6, 2003 | 09:34 PM
koco's Avatar
If you can mount the actuator at all you can usually sneak the actuator rod through somewhere. You'd be surprised. Also you can wire the actuator in reverse so it pulls the rod to unlock, that way your actuator faces the opposite way actually.
The part I hate most is running the wires out to the doors.
Old Mar 6, 2003 | 11:07 PM
philly-O's Avatar
Default Re: need help from those who have installed aftermarket power door locks in a civic (koco)
so true...running the wires is usually the hardest part of accuator install. goodthing is eventhough it seems difficult....the hardest part is over goodluck on the rest of the install.
Old Mar 7, 2003 | 06:43 PM
boostsohfast's Avatar
i put mine on about a 45 degree angle around where the back of the arm rests are on the door panels...i had ok clearance...i just had to bend the rods that run to the locks....its been working fine with no problems yet.
Old Mar 13, 2003 | 10:00 AM
iwhichisme's Avatar
just take the actuators and place right above the rods that connect to the locks on the inside. Place the about 3' above the rods, but on the inside of the door. Then you want to take the included rod, and bend them accordingly and connect them to the factory rods. Ill have pics soon or later here
hatchdrvr
Mar 4, 2003 04:30 PM
jaM3s Bond
Jan 7, 2003 06:02 PM
AmauryR
Audio / Security / Video
Dec 1, 2002 01:01 PM
anomaly
Aug 21, 2002 09:11 PM
TurBoXBirD16
Apr 30, 2002 03:01 PM
