AEM messed up my motor...
Old Mar 4, 2003 | 11:43 AM
HondaCutter's Avatar
Default AEM messed up my motor...
I just bought an AEM \fuel pressure regulator, and it was working fine when I got it. I din't do anything to it, just took it out of the box and put it on my rail.
Last night, I tried starting my car and it wouldn't start. Then, the engine locked up!!! I took out the spark plugs and they were soaked in fuel and you could see big puddles of fuel in my cylinders!!! Now, the engine is hydrolocked!!! Fuel was coming out of my turbo and it is in my oil. We took off the regulator and when we disconnected the vacuum line, fuel poured out. We opened up the regulator and found a gasket type thing that looks like it's supposed to be glued down, and it was...but only on half of the gasket. So, the other half was letting fuel from the rail go into my intake manifold via the vaccuum line.
So, I have a lot of lawyers in my family and I'm gonna see what they can do. But that's totally fucked up. I bought an AEM product because it's AEM and I figure they make reliable products, but I guess not...
Old Mar 4, 2003 | 11:49 AM
PM-Performance's Avatar
Default Re: AEM messed up my motor... (HondaCutter)
????? The diaphram if thats what your talking about , is not supposed to be glued down . its held down via spring . and pressure can be let out if spring pressure is too much and can flutter.
I dunno dude, i dont think your FPR did all that , i could be wrong though.
But good, luck, i have never heard of any of the such and im sure they will find a way out of it . but nonetheless good luck
Old Mar 4, 2003 | 11:54 AM
JT's Avatar
JT
Did you buy the fpr new or used? If it was used, perhaps the previous owner didn't assemble the fpr correctly. However, if it's new, then you should be compensated for any damge on your motor from AEM.
Old Mar 4, 2003 | 11:59 AM
underpressure02's Avatar
Can you not take the all the plugs out and drain the oil and crank the motor over and that should get rid of the hyrdo lock. I really do not think you have a case if you try and sue them. But I could be wrong. Good luck
Old Mar 4, 2003 | 12:06 PM
paulzy's Avatar
Default Re: AEM messed up my motor... (underpressure02)
this has hanppened with some of the cheap weapon-r and similar FPRs also
Old Mar 4, 2003 | 12:19 PM
K20Ahondas's Avatar
Default Re: AEM messed up my motor... (Paul_Vang)
That acutally happen to me but it was due to injectors getting suck open and cause it to fill the cylinder with gas. It hydro locked when i was cranking but didn't do any damage to the motor. just blew out all the gas and fixed the problem.
Old Mar 4, 2003 | 01:25 PM
MachAF's Avatar
Wow. The reason for parts to be more expensive. thx man!
Old Mar 4, 2003 | 02:39 PM
rioninja's Avatar
If there is no damage to the motor, then just have AEM replace the fpr.
AEM makes great products, but dont think that they never have defects.
DA TeG 90
Jan 27, 2010 03:10 PM
digital sol
May 28, 2007 04:37 PM
gsrjohnny
Oct 19, 2006 02:53 PM
pgpunkguy
Aug 3, 2004 02:19 PM
AussieK24
Apr 4, 2002 01:04 AM
