Aeromotive A1000 or AEM Fuel Pressure Regulator?
I have been looking at the Aeromotive A1000-6 Injected Bypass Regulator for my build for 2010 I see some also use the AEM. Shooting for 600+whp on c16 and want to see what you guys are using for your builds.
Will i need to replace the fuel rail as well? if so, I was thinking either AEM or golden eagle.
Re: Aeromotive A1000 or AEM Fuel Pressure Regulator?
that is what I was learning more towards. How about fuel rails? How much power is the stock fuel rail rated for? its a b17 fuel rail.
that aem reg is garbage went through 2 of them before i switched to the aeromotive and no complaint now and the rail is like 100 bucks so just pick one up
Never had an issue with either the AEM Universal or AEM Rail Mounted Regs, running 70-75psi of pressure as well.
i have an a1000 and an aem reg for sale for whats it worth lol.
My AEM has given the car great service with 800hp, ive inspected it before, its built well, the only thing i don't like is the size of the adjustment screw, but that doesnt really affect anything.
Im sure you are talking about the large universal regulator as i am
Bump for input on high pressure setups.
IIRC, the Aeromotive is limited to 70psi base pressure. . .?
Fuel lab makes two different types of fuel pressure regulators. Their base efi regulator can be adjusted from 25-90 psi base, and their high pressure ones can be adjusted from 90-125psi.
