Turboing a 11.4.1 Compression B18C1
The set up:
I got a GSR motor with jdm itr pistons. According to http://www.c-speedracing.com/howto/c...c/compcalc.php from cspeedracing, my compression is somewhere around 11.4.1.
My car is in the shop right now getting these items put on:
-maxrev kit
-garrett t3/t4 (.57 trim, .63 ar)
-3' thermal
-rc 550 cc
-walbro 255lph fuelpump
-hondata 2b
-skunk2 cam gears
-and a whole bunch of other electronics and miscellaneous things
How do yall think this set-up will run. I have been told that i will probably only be able to run 5psi SAFELY.
What are your inputs on this.
-maxrev kit
-3' thermal
-rc 550 cc
-hondata 2b
-skunk2 cam gears
I can honestly say I wouldn't run a turbo with that compression but with a really good tuner you can get by. Would you be able to use different pistons (IE 10.2:1 or 10.4:1 or lower)?
u can do it, but make sure you have some kind of engine management (hondata, EMS) and a tuner who knows his stuff.
I have talked to st00pid, im assuming most of yall know him.
He told me he was running a CR of 11.1 and has seen 12 psi of boost
on stock bottom.
So im assuming a pretty good tuner with CR 11.4 should be able to make
5 psi reletively safe.
on stock bottom.
Just curious. Where are you having your tuning done?
by a guy named ED. supposedly he graduated at Georgia Tech which as some of you may know is a really top notch school for engineers and all that.
b.d.racing
Mar 13, 2006 08:07 PM
jap-spec
Jan 16, 2003 09:35 PM
