95 civic headlight problems
My stock headlight went out, high beam and low beam. I replaced the bulb and it still didnt work. When I replaced the bulb i noticed the connector was kind of melted. So I replaced the connector. Still didnt work. I think I checked all my fuses, my fuse panel is missing the label so im not sure wich ones go to my headlight. Anyone have any suggestions on what this might be?
I say follow the wire back from the start of the headlight to see if you can figure it out then. Always start at the root of the problem
hah
Good Luck
Scott
hahGood Luck
Scott
