Headlight Problem
Old Jan 1, 2005 | 09:35 PM
Senbonzakura's Avatar
Default Headlight Problem
My driver side headlight doesn't work. I replaced the bulb because the original one was broken. But why doesn't it turn on?
Old Jan 1, 2005 | 10:17 PM
Dumped DB2's Avatar
Default Re: Headlight Problem (Kyo Kusanagi)
does the passenger side headlight turn on? are you sure u plugged the harness into the buln? did you get the right bulb? did u check your fuses? your question is vague, would be useful if you described your prob more
Old Jan 1, 2005 | 10:33 PM
Default Re: Headlight Problem (Pjct2ndGenTeg)
Sorry if its vague. But yeah, I got the right bulb and i plugged it in correctly.
My passenger side works fine. The driver side original bulb broke so i had to go out and get a new one. Its the low-beam headlight not the high beam.
Old Jan 1, 2005 | 10:44 PM
importdude2000's Avatar
check the plugs if the any prongs are burnt
Old Jan 1, 2005 | 10:45 PM
Default Re: (importdude2000)
Nada, perfectly fine.........plugs aren't burnt....
Old Jan 1, 2005 | 11:16 PM
calxtreme's Avatar
it's possible that you didn't stick the socket in far enough? Probe the socket with a voltmeter to see if there is power going to the bulb.
Old Jan 1, 2005 | 11:44 PM
Default Re: (calxtreme)
Its all the way in tightly. Could be electrical problem?
Old Jan 2, 2005 | 12:01 AM
thaiphob's Avatar
Nikon!!!
Default Re: (Kyo Kusanagi)
fuse>?
Old Jan 2, 2005 | 06:00 PM
calxtreme's Avatar
again, you need to check if there's power going through the harness by probing it.
Old Jan 2, 2005 | 06:04 PM
Problem fix, first it was my light bulb, then it was my fuse then it didn't work after a while, then i re-checked my light bulb again, it was broken.
Thanks for all the input
Old Jan 2, 2005 | 06:16 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyo Kusanagi &raquo;</TD></TR><TR><TD CLASS="quote">Problem fix, first it was my light bulb, then it was my fuse then it didn't work after a while, then i re-checked my light bulb again, it was broken.
Thanks for all the input </TD></TR></TABLE>
lol if its not one thing....its another. I had a similar problem, but it was the plug that was burnt out. Replaced it then it was fine. Then I just went with the JDM HID headlights.....
Old Jan 4, 2005 | 07:48 PM
calxtreme's Avatar
glad problem solved.
otsegolectric
Jul 22, 2008 10:47 AM
gold_ef
Oct 20, 2006 02:43 PM
Accorddrver
Apr 27, 2004 09:41 AM
slvrcivic97
Apr 12, 2003 11:23 AM
integra99blue
Jan 15, 2002 06:39 AM
