shifting technique
Old Mar 3, 2003 | 05:35 PM
jordan88's Avatar
Default shifting technique
I am just wondering, when shifting, if i step on the gas while pushing in the cluch and then shift. is that good to the car?
thx
Old Mar 3, 2003 | 05:36 PM
JReed's Avatar
Default Re: shifting technique (jordan88)
thx
no...
Old Mar 3, 2003 | 05:38 PM
asmallsol's Avatar
Unless you have a device like Honda data, this can be bad, you can easily over rev your engine. Also you can eat up your clutch pretty quick
...are you talking just touching the gas while your shifting or are you talking pedal glued to the floor while drag racing? First is ok, second is not that good.
[Modified by asmallsol, 2:38 AM 3/4/2003]
Old Mar 3, 2003 | 05:39 PM
Chris y0!'s Avatar
Default Re: shifting technique (JReedCivicMan)
what do you mean "good to the car"? where do you draw the line?
driving like an old lady isn't "good" for the car. every second your motor runs, it is deteriorating.
but to answer your question, you should only do it when you are drag racing.
Old Mar 3, 2003 | 05:40 PM
Chris y0!'s Avatar
Default Re: shifting technique (asmallsol)
thats why we have rev limiters. atleast thats why i have a rev limiter.
Old Mar 3, 2003 | 05:41 PM
JReed's Avatar
Default Re: shifting technique (Spoon Hybrid)
werd...
Old Mar 3, 2003 | 05:44 PM
Evs-One's Avatar
Solbros Owns Me
nothing is good for your car...but some things will help it last just a bit longer
Old Mar 3, 2003 | 05:52 PM
wildstallion's Avatar
Default Re: shifting technique (Emerica)
can someone enlighten me on how this would equal out to a qwicker shift???? or better????
Old Mar 3, 2003 | 05:59 PM
Chris y0!'s Avatar
Default Re: shifting technique (wildstallion)
the shift isn't quicker, but if you don't let off the gas, the car stays in high RPMs.
Old Mar 3, 2003 | 06:03 PM
EH2-LS-TURBO's Avatar
power shifting: shifting gears while holding down the gas
i tried it a coulple times...it kinda helps if you do it fast enough...but i stopped doing it after i misshifted and grinded my gears...eeek
Old Mar 3, 2003 | 06:04 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: shifting technique (EH2-LS-TURBO)
helps a lot on boosted cars...keeps boost in the charge pipes instead of dumping it out the BOV...PSHHH
nY's FiNeSt
26
Oct 3, 2003 05:30 AM
_Endless_
May 8, 2003 03:51 PM
NNtegGs
Sep 21, 2001 08:00 PM
