Tranny install. Grease the spline inside the clutch disc?
Old Mar 3, 2003 | 02:13 PM
niedejb's Avatar
Default Tranny install. Grease the spline inside the clutch disc?
Just need everyones opinion.
OEM manual states to grease the inner spline on the clutch disc and inner diameter of the throwout bearing.
I thought you wanted to keep the pressure plate and disc as far away from grease as possible.
What do you guys do?
[Modified by niedejb, 5:13 PM 3/3/2003]
Old Oct 22, 2006 | 05:32 AM
t0p_sh0tta's Avatar
Default Re: Tranny install. Grease the spline inside the clutch disc? (niedejb)
Just use a light coating, you don't have to pack it in there.
-Grease the splines of the clutch.
-The release fork
-Release bearing
-Release fork bolt (the thing with the round head)
-The splines on the tranny
Edit: What kind of grease do you plan to use? The manual specifies Super High Temp Urea Grease PN 08798-9002.
What would the part store equivalant of that be? I've used high temp wheel bearing grease without issue in the past.
Old Oct 22, 2006 | 06:16 AM
chasemyhonda's Avatar
B A N N E D
I just grease up the spline. Not super thick. but just a little more than a light coat so it will get the clutch disk.
i apply a little bit on the throw out bearing.
Generous amount on the release for Pivot ball
I used High temp Grease (Suspension components and Wheel bearings)
Old Oct 22, 2006 | 01:07 PM
inspyral's Avatar
Lucas makes a nice high temp urea grease. THey call it high temp wheel bearing grease or something like that. It's green and coumes in a 16oz tub for like $5.
Old Oct 22, 2006 | 01:10 PM
B A N N E D
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Lucas makes a nice high temp urea grease. THey call it high temp wheel bearing grease or something like that. It's green and coumes in a 16oz tub for like $5.</TD></TR></TABLE>
Bingo.. thats what i use.. cept the cover is all jacked up aand i dont know who made it.
Old Oct 22, 2006 | 01:18 PM
B18C Turbo's Avatar
I use supertech high temp grease, that stuff is amazing, its $5 at wal-mart for a nice jar of it!
Old Oct 22, 2006 | 01:19 PM
1992Si's Avatar
I'm still using the container of Pennzoil wheel bearing grease I bought back in the mid 70's. You just need a light coat.
Old Oct 27, 2006 | 01:16 PM
junior40er's Avatar
Default Re: (1992Si)
wwooahh WTF? Its still works??
UnknownDC2
Feb 17, 2008 12:32 PM
invboost
Nov 17, 2003 12:49 PM
mr_mbuna
Dec 4, 2002 04:04 AM
NONKonformyst
Oct 21, 2002 07:07 PM
