I lost 36 hp!!!
well on friday i went to have my car tuned. We got it on the dyno and when i first had my car dyno'ed back on December 17th, it made 176hp and 147 lbs/ft. well this time it only made 140hp. My number 1# cylinder has 150 compression all of the others have 200. I just had new rods, eagle, and pistons, JE, put in. We are thinking its my valves. What do u guyz think?? and if it is my valves what should i go with??
Nope, i have been talking to alot of people and it wasnt puffing smoke, we are almost positive that the rings are good. I planned on a leak down, but probably just take it to honda and have them figure it out.
Off the wall question but.....you sleeved the block, right?
something is wrong if your compression numbers are 150 200 200 200
You mean people are still putting forged pistons in stock honda H22 blocks....hahahhahaha, i'm sorry but that **** has been told over and over again! You can't do that ****!!
Sorry, when i did it I thought i could trust the place that did it but i guess not seeing how it took them 5 months and i got the car back in October sometime and im still having problems. It has been in and out of shops for the whole time. Time to get rid of it.
Guest
Posts: n/a
you CAN use forged pistons in the h22 block.... just have to use the right ones and clearance them properly.... i didnt believe it unill a few weeks ago when i met a guy that was running je pistons in a 97 lude w/o sleevs, 25k miles on the motor and it was still fine....
but 200psi per cylinder does suck, i was hitting 235 on my stock jdm h22a...
the only way to tell if it is hte valves is to do a leakdown test
preludedriva
13
Sep 3, 2007 12:34 AM
boosted_dc2
Oct 6, 2003 07:24 PM
That goes to show how great of job was done on my motor.
