went to the dyno yesterday........
Old Apr 17, 2002 | 02:00 PM
jinxproof99's Avatar
New User
Default went to the dyno yesterday........
i wasn't going to post this yet but seeing how people in my area already have heard............
448 hsp
282 tq
sae corrected on a fairly new dyno jet. it was like 92 degrees here yesterday!!
.......and for the haters.......it was on a stock honda block with.....oh my god.....a thicker headgasket.
stock gsr block
je 10:1 pistons
crower rods
inlinepro headgasket
ported head
haltech
t4 turbo@22.5 lbs.
DAILY DRIVEN
Old Apr 17, 2002 | 02:03 PM
b18bturbo's Avatar
Default Re: went to the dyno yesterday........ (jinxproof99)
damn thats not bad at all with stock block. is that with my turbo jinx
Old Apr 17, 2002 | 02:07 PM
ArizonaTurbo's Avatar
Great Numbers! The torque seems a little low, but the HP is right on! Good luck!
Old Apr 17, 2002 | 02:14 PM
paulzy's Avatar
Default Re: went to the dyno yesterday........ (TurbochargedSER)
having Je pistons and crower rods is considered stock? I'm not hating, just wondering....that means that I should be condisering my motor stock also
New User
Default Re: went to the dyno yesterday........ (b18bturbo)
yeah.
Old Apr 17, 2002 | 02:16 PM
New User
Default Re: went to the dyno yesterday........ (Slow_ass_4dr)
i just meant that the block itself was stock. no sleeving, boring, or blockgaurd. stock sleeves with 81mm forged pistons.
Old Apr 17, 2002 | 02:20 PM
New User
yeah, we thought so too. i have stock bore and stock cams set to 0 so we only tuned the gas/air/spark. i'm thinking the turbo is a little big for what i have now, but i'm adding a 84mm/sleeved block in 6 weeks so with that and alittle more fuel, that turbo is gonna make way more power/torque than i'll ever use pretty soon. we'll see.
Old Apr 17, 2002 | 02:21 PM
New User
Default Re: went to the dyno yesterday........ (94hondahybrid)
what octane you running?
vp c16......i think they rate it at 117 octane.
Old Apr 17, 2002 | 03:25 PM
FAST94GSR's Avatar
New User
Have you taken her to the track? That should be enough for you to dip into the 10's. Just curious why is the torque a little low? Is it taking a while for that turbo to buld up boost? Do you mind sharing how much this simple set up cost you?
Old Apr 17, 2002 | 03:39 PM
HybridHatchC1's Avatar
Default Re: went to the dyno yesterday........ (FAST94GSR)
i saw jinxproof car run at MIR last season, pretty quick, also you have some crazy cams in that thing or what, i have it on video when your pulling out of the pit area to the staging area and your car was idle was going up-down-up-down i love that ****.
Edit: hey do you know where i can get a 2.5 or 3in exhaust made at a decent price, i just realized your probably a local down at CDE and Inline pro would they do it or anywhere eles down there?
[Modified by Civ-JDM, 12:42 AM 4/18/2002]
Old Apr 17, 2002 | 03:43 PM
paulzy's Avatar
oh, I see...I should be in that club too then
Old Apr 17, 2002 | 03:50 PM
New User
Default Re: went to the dyno yesterday........ (Civ-JDM)
actually the cams are stock. as far as the exhaust goes, i have a 3" thermal. are you trying to have one custom made?? cde might do it and a guy in md, jeff. its called jeff's insane exhaust.....phone# is..301-855-0162. he does top notch work. custom cages as well. he built cages for me and a few friends as well as littlebluecrx's(jason hunt).
Old Apr 17, 2002 | 03:52 PM
New User
i'll be at the track this weekend. should hit 10's at some point. we'll see.
Old Apr 17, 2002 | 03:58 PM
Xerxes's Avatar
New User
Nice numbers! . Just curious, why do you have a thicker headgasket and 10:1 JE pistons instead of a normal headgasket and 9:1 pistons?
do you think that this could account for the lower torque, i.e. changing the shape/quench of the combustion chamber?
-Xerxes
Old Apr 17, 2002 | 04:10 PM
pkripper's Avatar
New User
Default Re: went to the dyno yesterday........ (Xerxes)
wouldnt he have lower torqe yet if he had 9/1 comp.
post some times as soon as you can i am curious to see what that hp will do.
i am still considering keeping my teg and puting in the new motor. I hope you dip into the 10s.
Old Apr 17, 2002 | 04:22 PM
AlphaKennyWun's Avatar
Default Re: went to the dyno yesterday........ (pkripper)
Jinxproof, have you ever had an incident where the headgasket shifted due to no blockguard or high mileage sleeves becoming unsettled with high boost? Im just wondering cause aside from shattering a stock sleeve, or swallowing a valve, my next highest concern with a stock block is headgasket shifting.
Old Apr 17, 2002 | 04:24 PM
2K_TEG's Avatar
Default Re: went to the dyno yesterday........ (SO3Burner)
OT: what size injectors are you running?
Old Apr 17, 2002 | 04:25 PM
BoostinDC2's Avatar
Default Re: went to the dyno yesterday........ (2K_TEG)
nice numbers
Old Apr 17, 2002 | 04:31 PM
Phantom's Avatar
450wph daily driven? thats weak
but why the higher comp pistons + head gasket? Couldn't you achieve the same comp and possibly better results by simply using a stock head gasket and lower compression pistons?
[Modified by Phantom, 8:32 PM 4/17/2002]
Old Apr 17, 2002 | 04:34 PM
LsTurbo91's Avatar
Default Re: went to the dyno yesterday........ (Phantom)
heh, maybe its to promote there headgasket
Old Apr 17, 2002 | 04:39 PM
Default Re: went to the dyno yesterday........ (LsTurbo91)
maybe the gasket lowers the compression less than a hole point to like +/- 9.5:1 thats my guess
Old Apr 17, 2002 | 05:35 PM
dragnGSR's Avatar
Awesome numbers Jinx!!!
Old Apr 17, 2002 | 05:52 PM
Default Re: went to the dyno yesterday........ (dragnGSR)
Inline pro has a world famous gasket i think a turbo car without one is a turbo car in need of one.
Old Apr 17, 2002 | 05:56 PM
RoaringTurtle's Avatar
New User
great numbers
Old Apr 17, 2002 | 09:22 PM
SIK IN DA HED's Avatar
New User
Default Re: went to the dyno yesterday........ (RoaringTurtle)
DAYAM... good #s man.
