carthec fmu install + driving without turbo connected
Old Mar 2, 2003 | 03:31 PM
Wicked Sol's Avatar
New User
Default cartec fmu install + driving without turbo connected
Is there any problem with driving around with the turbo connected to the exhaust manifold but no to the intake? I just wanted to drive around for a few miles to make sure I have all the bugs worked out.
Also I'm running extremely rich just at idle and wanted to make sure I have my cartech fmu inbstall correctly. I connected the return from the factory regulator to the in on the cartech and the out is the return, then I T'd off the factory regulator for vaccum. The thing I'm unsure about is there is a little ****. Does this get a vaccum line attached and what exactly does it do? I thought the allen screw in the center was for adjusting fuel pressure at idle.
[Modified by Wicked Sol, 12:32 AM 3/3/2003]
Old Mar 2, 2003 | 03:50 PM
DeepSi's Avatar
Default Re: cartec fmu install + driving without turbo connected (Wicked Sol)
if you run with the turbo not connected to the intake pipe, you will run the chance of over revving your turbo and killing it.
Old Mar 2, 2003 | 04:46 PM
B20-T's Avatar
Default Re: cartec fmu install + driving without turbo connected (DeepSi)
just take out the w/g spring
WorkedDelSol
Jun 28, 2006 10:22 AM
Ryan C
May 26, 2003 08:36 PM
Boosted Gsr Hatch
Feb 22, 2003 06:38 AM
sushibug
Jun 29, 2002 04:59 PM
NeXtLeVeL_TyPe_R
May 30, 2002 12:49 PM
