turbo installed a few problems. HELP!!
Old Feb 21, 2003 | 09:26 PM
Boosted Gsr Hatch's Avatar
Default turbo installed a few problems. HELP!!
i just installed my drag gen turbo kit and im having a few problems with it.The first, my car's idle was surging between 1000 and 3000 rpm. i threded the FICV under the t- body and that helped but now it idles and 1500 and fluctuates about 200 rpm. i adjusted the idle screw all the way down till it gets to 1500 rpm.Any thoughts.
Second,
when i accelerate my car will hessitate a little then between 4000 and 6000 it will hessitate and king of bogg like the rpms dont get any higher. i didnt adjust my timing yet, so could that be it. it feels like it does it arounf the vtec crossover.
Any help will be appreciated
Old Feb 21, 2003 | 09:30 PM
Tofurky's Avatar
Default Re: turbo installed a few problems. HELP!! (Boosted Gsr Hatch)
did you use the missing link? or map bypass?
and how did you set up the FMU? you placed it after the fuel rail, right?
Old Feb 21, 2003 | 09:34 PM
Default Re: turbo installed a few problems. HELP!! (Ruckus138)
i am using missing link,. the fmu is installed on the driver side of the car. hose from the bottom is running to fpr, and the side is running to the fuel line from the tank.
Old Feb 21, 2003 | 11:20 PM
BoostedGSRBubble's Avatar
Which fmu, 12:1? You may be running too rich and thus the hesitation.
Old Feb 21, 2003 | 11:28 PM
CzanSOHC's Avatar
Default Re: turbo installed a few problems. HELP!! (BoostedGSRBubble)
Check for a vaccum leak, thats prolly the problem w/ your idle.
Old Feb 22, 2003 | 06:38 AM
niedejb's Avatar
Got the plumbing backward
kun3racer
Sep 27, 2004 07:15 AM
bumpin_bass
Oct 9, 2003 09:20 AM
Chrome Pipes
May 23, 2003 10:01 AM
V8 BAIT
Jun 18, 2002 03:53 PM
NeXtLeVeL_TyPe_R
May 30, 2002 12:49 PM
