obd2 question
Old Feb 28, 2003 | 01:46 PM
prada_2o0o's Avatar
Default obd2 question
I did a b16a2 swap into my 97 civic si-g. I switched both harnesses so the swap was plug and play. I am now taking out my b16a2 to keep for a eg hybrid(it has 20k on it) and putting a d16y7 so i can sell my car. Now my question is if i use the d16y7 engine and engine harness will the harness behind my dash need to be changed back aswell??? i have been told a few things but i am doing my swap this weekend and would like to know if i have to switch that harness as well so i can get one. Also is there anyway to rewire the harness where it plugs into the ecu(color to color)??? so i dont have to pull thewhole dash out to changeit once again.
Thank you for your help
Old Feb 28, 2003 | 01:49 PM
4g4me's Avatar
Default Re: obd2 question (prada_2o0o)
damn, you actually did that swap? Wow, congrats from someone who pulled his dash out and still didnt do it.
I am a *****
Old Feb 28, 2003 | 03:26 PM
DragII's Avatar
25 Year Member
Default Re: obd2 question (4g4me)
what year is the d16y7?
Old Feb 28, 2003 | 03:35 PM
prada_2o0o's Avatar
Default Re: obd2 question (DragII)
it is from a 96... i have heard that since the harness in there is a 00obd2 harness it wont work somehting about obd2a and obd2b??
Old Feb 28, 2003 | 04:58 PM
DragII's Avatar
25 Year Member
if the motor is 96, and your car is 97 you will have no problems. wiring didn't change until 99-00
Old Feb 28, 2003 | 05:04 PM
prada_2o0o's Avatar
it is a 97 yes.. but i previously installed my b16a2 including all wiring.. so now all the wiring is 2000.....imjus wondering if i throw the 96 dx back in will the engine harness and ecu work with the 00 harness
Old Feb 28, 2003 | 05:17 PM
b16 matt's Avatar
no you will probably need a back date harness.
Old Feb 28, 2003 | 05:19 PM
prada_2o0o's Avatar
Default Re: obd2 question (b16matt)
where do i get one of those.. or do you mean the 96 dx harness.... also is it possible to take the connectors off the 96dx harness and match them color for color on my 00 b16a2 harness.... and just plug it in .. or does that mean i have to take the whole dash out again..
D_koschak
Mar 23, 2016 11:14 PM
envision
Oct 15, 2015 10:41 AM
thehatch97
Dec 15, 2009 09:48 PM
prada_2o0o
Mar 14, 2003 07:40 PM
SC61HB
Jan 27, 2003 01:56 PM
