anyone have a Techedge V1.5 wideband??
Old Feb 23, 2003 | 06:53 PM
Boostless97Lude
Guest
Posts: n/a
Default anyone have a Techedge V1.5 wideband??
do the cables coming in, and going out of the display unit carry the same information?
Old Feb 23, 2003 | 07:29 PM
LJR-LUDE01's Avatar
Default Re: anyone have a Techedge V1.5 wideband?? (Boosted97Lude)
sorry this is not an answer but do you haave pic of where you install your display? I'm trying to figure where to install mine
Old Feb 23, 2003 | 07:31 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: anyone have a Techedge V1.5 wideband?? (LJR-LUDE01)
no pic, but it's under the radio
NO ONE HAS A V1.5?!?!?!
Old Feb 23, 2003 | 08:10 PM
keebler65's Avatar
no they do not. one carries ground, power, and voltage input. this one connects to the WB unit. the other carries RS-232 signal for data logging and ground. this would go to a computer. however, the v.1.5 does not use this cable, since if you're datalogging you'll want to plug your computer right into the WB unit. in other words, you can either use your computer or the display, but not at the same time unless you make a Y adaptor because they both plug into the DB-9 connector on the WB unit.
Old Feb 24, 2003 | 10:50 AM
GOLDBERG's Avatar
Default Re: anyone have a Techedge V1.5 wideband?? (keebler65)
i have a v1.5...anyone know what the weird white thing is for?
Old Feb 24, 2003 | 11:46 AM
keebler65's Avatar
Default Re: anyone have a Techedge V1.5 wideband?? (GOLDBERG)
can you elaborate? are you talking about the white cable? if so, thats for the various inputs and outputs, such as vuser1, vuser2, NBout, RPM in, etc. other than that, i dont know of any "weird white thing"
Old Feb 24, 2003 | 11:59 AM
Boostless97Lude
Guest
Posts: n/a
i asked that question abotu a month and a half ago... go here https://honda-tech.com/zerothread?id=370986
Old Feb 24, 2003 | 12:07 PM
keebler65's Avatar
otherwise the info has been on the techedge site for some time now...
http://www.techedge.com.au/vehicle/wbo2/1v5/const.htm
scroll towards the bottom of the page
bmfbmf
Audio / Security / Video
Mar 28, 2012 07:37 AM
n2omike
Dec 8, 2008 10:30 PM
nikolai.
Jan 24, 2005 01:57 PM
Boostless97Lude
Jan 1, 2003 07:43 PM
