where does this hose go? ITR intake mani. pic
Old Feb 23, 2003 | 06:16 PM
baonest1's Avatar
Default where does this hose go? ITR intake mani. pic
i noticed this loose hose lately. it may be the answer to my problems, maybe not. where does it lead to.
ive looked underneath. havnt really found anything it goes to. maybe im blind.
appreciate the help and the comments
Old Feb 23, 2003 | 06:19 PM
sgT's Avatar
sgT
Default Re: where does this hose go? ITR intake mani. pic (baonest)
goes into the catch can on the back of the block
Old Feb 23, 2003 | 06:22 PM
baonest1's Avatar
Default Re: where does this hose go? ITR intake mani. pic (sgT)
hmmm well i have an LS block. wats my alternative.. can i block it off with a screw or somthing.
Old Feb 23, 2003 | 06:24 PM
Art Vandeleigh's Avatar
arent you also missing a hose form the crankcase?? the pcv?? i forgot to plug that back once and oil spewed everywhere...
Old Feb 23, 2003 | 06:28 PM
sgT's Avatar
sgT
you mean 96+ ls block?
Old Feb 23, 2003 | 06:29 PM
baonest1's Avatar
yah.. its 97 block
Old Feb 23, 2003 | 06:31 PM
sgT's Avatar
sgT
then take the pvc line off the intake manifold and plug it.
you will want to add a few vents to the block though
Old Feb 23, 2003 | 06:37 PM
baonest1's Avatar
a few vents to the block.... sounds complicated. how do i accomplish that.
Old Feb 23, 2003 | 06:58 PM
sgT's Avatar
sgT
ummm, take a drill, and a 1/2" drill bit, and make a bunch of holes.
or you could take out the plugs in the back and put fittings in them
Old Feb 23, 2003 | 07:05 PM
baonest1's Avatar
haha.. well damn. not so complicating.
Old Feb 23, 2003 | 07:48 PM
Batoutahell's Avatar
ahem, they'se called "speed holes"
Old Feb 23, 2003 | 09:23 PM
stormywaters's Avatar
Default Re: where does this hose go? ITR intake mani. pic (Batoutahell)
they make the car go faster.
Old Feb 23, 2003 | 09:27 PM
sgT's Avatar
sgT
Default Re: where does this hose go? ITR intake mani. pic (stormywaters)
i like to use them to fill oil
Old Feb 24, 2003 | 02:22 PM
Four Door LS VTEC's Avatar
I just ran into the same problem switching from a 94 LS block to a 98 LS block.
Exactly where would be the best place to drill these block vents and about how many?
What keeps the oil from coming out of these holes?
Old Feb 24, 2003 | 05:01 PM
Default Re: where does this hose go? ITR intake mani. pic (Four Door LS VTEC)
anyone?
Old Feb 25, 2003 | 04:31 AM
maybe today?
Old Feb 25, 2003 | 08:02 AM
sgT's Avatar
sgT
Nobody reads anymore....
Old Feb 25, 2003 | 08:11 AM
well, i read the replies and still wasn't clear on the best solution. I searched and found a couple post that made a lot more sense then the replies here. Below are some of the links which cleared this up for me.
here is a link for a catch can setup to use the pcv and a moroso catch can.
https://honda-tech.com/zerothread?id=286769
and bsq's do-it-yerself way(the way i plan to do it):
http://www.geocities.com/bretq/DIY_O...tructions.html
or the endyn kit which is expsesive but pretty much foolproof:
http://www.theoldone.com/components/breather/
hope this helps any one that was still wondering.
[Modified by Four Door LS VTEC, 12:13 PM 2/25/2003]
Old Feb 25, 2003 | 10:20 AM
baonest1's Avatar
good deal. thanx
Josueneta
Apr 21, 2011 04:56 PM
dartonh22
Mar 21, 2008 10:38 PM
redman223
Jun 8, 2007 07:58 AM
CO_CReX
Apr 29, 2007 06:44 PM
GOLDBERG
12
Jan 23, 2005 03:45 PM
