hybrid grille, mix and match
Old Feb 23, 2003 | 05:05 PM
Chris y0!'s Avatar
Default hybrid grille, mix and match
take a look at this picture. more specifically, part #3. this is the outer molding of my stock civic CX grille, already painted white from the factory.
now take a look at part #1 in this picture. it is the base to the SI grille. now i have a theory... can i put my stock CX grille molding on this SI base? that would give me an instant Type R grille, that i wouldn't have to paint, and would cost me 60 dollars. thanks for the help.
[Modified by Spoon Hybrid, 2:06 AM 2/24/2003]
Old Feb 23, 2003 | 05:22 PM
The Destroyer's Avatar
Default Re: hybrid grille, mix and match (Spoon Hybrid)
theoretically it should work
Old Feb 23, 2003 | 05:23 PM
Default Re: hybrid grille, mix and match (5thgenhybrid)
BTW it wont cost 150$ liek the guy that went to honda and got one and a for being on his toes.
Chris y0!'s Avatar
yes, unfortunately i havn't seen anybody do this, so its a 60 dollar risk for me
thats what got me thinking about this. i was gonna get a knockoff grille but it looks nothing like the real one, and i would still have to paint the thing! if my theory worked i could keep it OEM and wont have to paint jack diddly.
[Modified by Spoon Hybrid, 2:28 AM 2/24/2003]
Old Feb 23, 2003 | 05:25 PM
tayl0R's Avatar
ok, i am not sure if i am going to get this exactly right. my bf has a 00 ex and tried to replace it with the si grill. he thought that it would work but now, he has to replace the stock grille molding with the si molding.
Old Feb 23, 2003 | 05:28 PM
Chris y0!'s Avatar
Default Re: hybrid grille, mix and match (sancletayley)
hmm, bummer. anybody else?
Old Feb 23, 2003 | 05:29 PM
sounds right, ask him what the diff is. like lets say for instance the Si/CTR grills are a few mm longer or something.
[Modified by 5thgenhybrid, 6:30 PM 2/23/2003]
Old Feb 23, 2003 | 05:33 PM
Type R106's Avatar
New User
Nope, will NOT work. go to the link below and check out the difference between the Si molding, and the Non-Si molding. The Si molding is much thicker than the Non-Si molding, therefore it will not fit.
https://honda-tech.com/zerothread?id=423902
Old Feb 23, 2003 | 05:36 PM
fowler!'s Avatar
Default Re: hybrid grille, mix and match (Type R106)
True true. When I originally bought my Si grill I had the same thought. But when you look at the two up close, you'll notice how far away it would be from fitting.
Old Feb 23, 2003 | 05:38 PM
Chris y0!'s Avatar
i really want to be sure about this. because i have had my grille apart, and the molding looked just as deep without that black center section.
Old Feb 23, 2003 | 06:03 PM
IDriveHonda's Avatar
the Si grill is deeper than the other grills. The black inner piece is recessed a couple inches back, and on the others, ther is like a 1/4 inch recess. It wouldn't work, and if it did, it would look wrong. Just buy an Si grill from someone who has replaced it with a body kit, that is your best bet.
Old Feb 23, 2003 | 06:04 PM
Chris y0!'s Avatar
Default Re: hybrid grille, mix and match (IDriveHonda)
results are in!
i just ripped off my bumper (im a pro) and checked out the grille again. damn, there is no way my theory would work
oh well, thanks for all your help guys
[Modified by Spoon Hybrid, 3:05 AM 2/24/2003]
Old Feb 23, 2003 | 06:39 PM
Briman2021's Avatar
you can buy a sheet of that mesh stuff from summit or jc whitney for like $25 bucks, and put it in your stock grill, you jsut hafta cut out the plastic fin things.
I did it with home depot mesh, you can tell the difference and it cost me $1.99
pics are here....
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
and
looks almost identical to the CTR and SI grills i have seen.
Old Feb 23, 2003 | 06:50 PM
Chris y0!'s Avatar
Default Re: hybrid grille, mix and match (Briman2021)
im probably gonna go with the knockoff from tornactive.com
its the most realistic knockoff ive seen
Old Feb 23, 2003 | 07:32 PM
racecarpete's Avatar
it actually does work but it doesn't look good at all, later
Old Feb 23, 2003 | 09:10 PM
Cruiser G's Avatar
You're bf is a smart man Nope, it doesn't work
[Modified by Cruiser G, 6:12 AM 2/24/2003]
The Hooligan
Northeast (Sales)
Nov 24, 2009 02:12 PM
Yokohama
Jan 12, 2004 10:43 AM
92civeg
Oct 11, 2003 04:18 AM
Who Said
26
Apr 18, 2003 05:27 PM
yaya
34
Nov 8, 2002 03:27 PM
