Flywheel install question
Hey just wondering what would happen if
the flywheel bolts were torked in the wrong
pattern. like hitting a bolt then skipping two
forward.
forward.
Re: Flywheel install question (Jago)
As long as your skipped a couple and torqued the bolt then retorqued each a couple of times you should be all good. If you just torqued each bolt down one time for each that might not be enough.....
I went around three or four times. tourqing to 80 foot pounds
[Modified by Jago, 4:41 AM 2/23/2003]
I tightened all of the bolts by hand first, then a cris cross pattern with the torque wrench. Also don't forget the threadlocker. I used the blue kind
I used the red stuff
[Modified by Jago, 10:43 AM 2/23/2003]
Good luck crackin those bolts. Without an impact wrench, I don't think you can break the red
Re: Flywheel install question (97hb)
