CTR CF Gauge Bezel into SI Gauge Cluster?
i was wondering how to install a CTR CF Gauge Bezel into an SI Gauge Cluster?
i opened it up and was going to install it, but realized that there's a key opening on the cluster (bottom left between tach and speedometer) which prevents me from putting it in.
anyone had this done?
i know someone who did it, but don't know how. do you guys take it out? what is that key opening for anways?
I cut the maintenance switch off altogether
some people actually make a hole in the ctr bezel
but I didnt want to since I never use that maintenance thing anyway
I always track my maintenance by mileage
here is a pic of my cluster
[Modified by RoaringTurtle, 9:59 PM 2/23/2003]
Most people order the canadian cluster cover (it doesnt have the maitenance thing) and just remove the whole thing all together. After you get it in check this how to out:
http://members.tripod.com/brokenlimitsorg/doorajar.htm
indicator when it turns orange, then red. Or do you just leave it red and call it a day.
Thanks.
I removed the whole maintence reset button all together. Forgot how I did it, but if you are technically inclined you can figure it out. It was really easy.
Oh and the benifit of doing this way versus cutting it off is that it no longer rolls and will stay green.
If you want to just cut it off, just use some wire cutters and cut it off.
good to know though
I have another spare cluster, so I can put back the maintenance button in the future if I need to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokenLimits »</TD></TR><TR><TD CLASS="quote">Most people order the canadian cluster cover (it doesnt have the maitenance thing) and just remove the whole thing all together. After you get it in check this how to out:
http://members.tripod.com/brokenlimitsorg/doorajar.htm</TD></TR></TABLE>
hmm...this post is OLD...but...i reallie was lookin to do this to my Si next, because it is cheep, and i THOUGHT it would be easy. but yah...cutting off the maintinence switch...how would i go around dooing that? and how hard would it be to just cut a hole in the carbon fiber? 2nd question, do you lose your door ajar light when you switch to the ctr gauge trim? please IM me....or jus e-mail me at ayewanrice@aol.com thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-ITR-373 »</TD></TR><TR><TD CLASS="quote"><BLOCKQUOTE>quote:<HR>I cut the maintenance switch off altogether<HR></BLOCKQUOTE>
I like the look without the maintenance switch. This is probably a stupid question, but I can't think of the answer right now, how do you reset the green color
Thanks.
Stick your key in the hole to reset it.
Thanks.
