Flywheel install question
Old Feb 22, 2003 | 07:31 PM
Jago's Avatar
Default Flywheel install question
Hey just wondering what would happen if
the flywheel bolts were torked in the wrong
pattern. like hitting a bolt then skipping two
forward.
Old Feb 22, 2003 | 07:33 PM
aw1234dude's Avatar
Default Re: Flywheel install question (Jago)
As long as your skipped a couple and torqued the bolt then retorqued each a couple of times you should be all good. If you just torqued each bolt down one time for each that might not be enough.....
Old Feb 22, 2003 | 07:40 PM
Jago's Avatar
I went around three or four times. tourqing to 80 foot pounds
[Modified by Jago, 4:41 AM 2/23/2003]
Old Feb 22, 2003 | 07:47 PM
aw1234dude's Avatar
ehhh, should be good
Old Feb 22, 2003 | 07:55 PM
97hb's Avatar
I tightened all of the bolts by hand first, then a cris cross pattern with the torque wrench. Also don't forget the threadlocker. I used the blue kind
Old Feb 23, 2003 | 01:43 AM
Jago's Avatar
Default Re: Flywheel install question (97hb)
I used the red stuff
[Modified by Jago, 10:43 AM 2/23/2003]
Old Feb 23, 2003 | 03:25 AM
97hb's Avatar
Good luck crackin those bolts. Without an impact wrench, I don't think you can break the red
Old Feb 23, 2003 | 09:20 PM
jdmcivicek's Avatar
Thats OK he's got a SNAP-ON cordless impact
scrubdakiller80
Sep 23, 2016 04:56 AM
ramboPandA
May 4, 2016 09:54 PM
98EJ
Jun 11, 2004 10:44 AM
AK94GSR
Mar 21, 2003 01:10 PM
Mikey3000
Nov 24, 2002 06:45 AM
