B18C1 SMOG Prob's
Old Feb 20, 2003 | 10:07 PM
Turbo(less)DB8's Avatar
Default B18C1 SMOG Prob's
I got a 94 civic dx coupe with a USDM 95 B18C1 and am having HUGE problems passing smog. The issue the HC's. they are about 100 higher then they should be. the engine is stock and I just got a new cat. My ECU is a skunk2 chipped P28. Any help would be good. Thanks.
Old Feb 20, 2003 | 10:20 PM
Qfactor's Avatar
Default Re: B18C1 SMOG Prob's (nscivic)
get a gsr stock program for your engine, your ecu is dumping more fuel which gives you higher HC's and CO.
Old Feb 20, 2003 | 10:27 PM
PoW3l2BaN's Avatar
yeah..its the skunk program for sure...the engine should pass without a prob..are you rockin the skunk2 intake manifold too? if not then you shouldnt be using the p28. Other than that..find yourself a obd1 p72 ecu...which will run you about 200 bucks...or borrow one from a homie...you should be fine..
Old Feb 20, 2003 | 10:34 PM
That's what I thought. Anyone got a p72 hangin around? I got 2 shinny $100 for em.
Old Feb 20, 2003 | 10:37 PM
GTlvr82's Avatar
I pity you west coast guys...We might have a smog program by the year 2007...in Pa. Good luck man.
Old Feb 20, 2003 | 10:50 PM
Qfactor's Avatar
Default Re: B18C1 SMOG Prob's (GTlvr82)
I just learned that the OBDIII will be using a GPS to track and monitor the emissions of the vehicle and the goverment will know where you go too. there's going to be a switch to turn off the GPS but you will have take your car to get smoged every year, this will probably will be around the year 2007 or 2010.
Old Feb 20, 2003 | 10:59 PM
Here's another question for ya. What engine paperwork do I need to have when I go to a SMOG ref?
Old Feb 20, 2003 | 11:30 PM
Qfactor's Avatar
when i took my car to the ref. they didn't ask for papers on the engine, here's what they did they did the visual inspection making sure vacuum hoses are connected,mil light works,timing and everything as to be in stock form no aftermarket fuelrails,cam pulleys btw if you don't have the t belt cover they won't put it on the dyno (liability, a small rock may fall into the opening and cuasing some engine damage)after the dyno you get the bar sticker and pay your $38.25 if it does not pass you pay $30.00 and get a second chance. and make sure you get there on time. they will skip you if you're not there on time and will have to wait. each ref station may vary depending on the refs. doing the certification. it took me four times to get my car legal 1st. no t-belt cover 2nd air cleaner vacuum operated resonator(which I had to prove that it was not emission related)passed the tailpipe but failed the visual 3rd. passed visiual failed tailpipe. 4th pass visual and emissions. hope you have better luck
Old Feb 20, 2003 | 11:58 PM
Default Re: B18C1 SMOG Prob's (Qfactor)
Can the engine be mismatched? (i.e. 95 block, 98 head, 95 everything else)
Old Feb 21, 2003 | 05:29 AM
Qfactor's Avatar
yes as long as the year of the block is not older than the vehicle its in. it has to be the same year or newer.
phrenzykEG6
Apr 19, 2010 06:35 AM
dohctor_B
Oct 1, 2005 05:37 PM
out_of_order
13
Apr 14, 2005 10:27 PM
