i turn my key, and like two seconds later my car starts to turn over
it starts but it just seems like it takes two seconds to get signal????????////??///
sounds like a starter/ solenoid, does it click when you first turn the key?
also check your battery connections
The only things that I can think of are loose or dirty connections from the Battery to the Starter Solenoid or an out of adjustment/faulty Starter Clutch Interlock Switch..
A weak Battery shouldn't cause this problem.. But it would cause a growling Starter start up...
That's what I "think".. I could be wrong..
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
check your main relay, it is not that it is delayed, it just looses contact there and does not send signal to the starter. my legend had the same problem, after two starters, one mechanic that told me i need a new ECM, i took the main relay out, and resoldered heat fatigued contacts on it. never had the problem again.
stan
stan
