rebuilt dizzy...tdc code 8 now
Old Feb 19, 2003 | 10:31 PM
gvillehnut's Avatar
Default rebuilt dizzy...tdc code 8 now
I just rebuilt my obd0 b16 distributor, with new shaft bearing, cap, and rotor. Everything is exactly as before except im throwin code 8 sometimes now. Does this mean i need to replace the sensor or what? It runs good and strong still so i dont think its my timing. TIA
Old Feb 19, 2003 | 11:46 PM
Ekasey's Avatar
Default Re: rebuilt dizzy...tdc code 8 now (black90b16)
well honda is a great company for there wide range of use of the ac pulse type sensor. This sensor generates volatage off of the principle of mutual induction there is a chnace you have either damaged this sensor or it is just plain bad, my question is how some you didnt just buy a new distributor
Old Feb 20, 2003 | 12:19 AM
gvillehnut's Avatar
Default Re: rebuilt dizzy...tdc code 8 now (eLusive ek4)
well for 1 i dont know what or where that sensor is your talking about, and i rebuilt my dizzy for 40 dollars, thats alot cheaper than a new one that will have an old bearing in it that will go bad in probably the same amount of time mine did.
Old Feb 20, 2003 | 10:18 AM
V3locity's Avatar
anyone? I'd like to get his car running right. It's been problem after problem for over 6 months. I'd really like to see this car actually run right for once.
Up up and away for stephen
Old Feb 20, 2003 | 07:12 PM
Ekasey's Avatar
Default Re: rebuilt dizzy...tdc code 8 now (illdezignzls)
sorry about that this sensor is located inside your distributor so you prolly whacked it or something
Old Feb 20, 2003 | 07:48 PM
gvillehnut's Avatar
there is lots of things and lots of wires inside my distributor... specifics?
Old Feb 20, 2003 | 11:49 PM
Qfactor's Avatar
check the gaps between the wheels and sensors.
Old Feb 21, 2003 | 12:00 AM
Ekasey's Avatar
Default Re: rebuilt dizzy...tdc code 8 now (Qfactor)
it should be a lil black box on the side of your distributor, it should be horizontal to a 4 pointed pin wheel
sebTeggy
Oct 21, 2011 09:28 PM
traybert2003
Feb 8, 2007 09:41 AM
hybridEj6
Sep 11, 2003 06:41 PM
sander
Apr 25, 2003 08:17 AM
