apexi n1 with turbo
Old Feb 19, 2003 | 07:33 PM
mrod006's Avatar
Default apexi n1 with turbo
i need some feedback. I have an apexi n/a muffler on my car. it will soon be turbo. would i need to get the turbo muffler? i will probably get 3" piping.
Old Feb 19, 2003 | 07:34 PM
Daniel's Avatar
Default Re: apexi n1 with turbo (mrod006)
probably, seeing as how i don't think the N1 N/A uses a 3" inlet.
Old Feb 19, 2003 | 07:50 PM
mrod006's Avatar
Default Re: apexi n1 with turbo (Daniel)
the inlet is about 2.5 inches. i think that the muffler shop can flare it out, but my concern is the outlet. is the n/a outlet too small for turbo?
Old Feb 19, 2003 | 07:54 PM
Daniel's Avatar
unless the actually piping running THROUGH the canister increases to 3", flaring a 2.5" inlet will do nothing. you flare it out to fit 3" piping, and then what? it bottle necks back to 2.5" piping inside the muffler. i've seen the inside of both a N1 n/a and n1 turbo, and i don't recall either having the piping increase size inside the muffler.
Old Feb 19, 2003 | 08:05 PM
mrod006's Avatar
so i would have to sell the n/a and buy the turbo?
Old Feb 19, 2003 | 08:08 PM
MiraiZ's Avatar
you"ll be okay...its wat I have, but it makes the car REALLY quiet....
Old Feb 19, 2003 | 08:15 PM
mrod006's Avatar
Default Re: apexi n1 with turbo (MiraiZ)
that is what i like about the exhaust. the fact that it is quiet is good because i am going for the sleeper look. what size of piping do you have?
Old Feb 19, 2003 | 08:21 PM
MiraiZ's Avatar
The N1 piping is 2.36 ( I think...60mm) then my DP is 2.25->2.4"...so its..
Turbo--->2.25"dp---->2.4"pipe---->JDM cat---->N1 full exhaust 2.36"
When I say quiet...its not Cadillac quiet...the exhaust is very throaty and much quieter than it was when it was NA...
Old Feb 19, 2003 | 08:24 PM
mrod006's Avatar
would you think that it would be useless if i got my piping 3" because of the size of the inlet on the muffler?
Old Feb 19, 2003 | 08:36 PM
Tetsuwan Atomu's Avatar
have to agree....n1 sounds very nice with turbo..u could actually hear ur music in normal volume in fwy...but n/a...n1 is loud!!!!
Old Feb 19, 2003 | 09:09 PM
Night_Minx
Guest
Posts: n/a
if you are less than 2 liters in displacement and less than 250 hp, youll be fine with n1. I have it on mine, with a 2.5" testpipe. Everything fits, works, and spools perfectly fine and good. Its a great setup. I have it on my 96' ex (greddy turbo).
[Modified by Night_Minx, 6:10 AM 2/20/2003]
Old Feb 19, 2003 | 11:23 PM
ZentraediEK's Avatar
Default Re: apexi n1 with turbo (Night_Minx)
I have the complete apex N1 N/A piping and muffler on my GSR/Drag 3 and it's very quiet . I'm making 250hp, but it feels very restrictive, like I'm losing a lot of power. Any suggestions?
Old Feb 20, 2003 | 12:39 AM
MiraiZ's Avatar
Default Re: apexi n1 with turbo (ZentraediEK)
get a dyno and see where the power starts to drop off...if its like towards the end of the curve...then it may be your exhaust is too restrictive...if it looks to still be climbing a bit or even level toward the end, then its something else
as far as the exhaust note...for a lack of better description, my car sounds like a WRX at idle (heavy and throaty)...then a bit more high pitched and raspier at higher rpms...I assume it gets really strung at higher boosts... I was too chicken **** to go above 7000rpms because by EBC wasn't holding boost...but when I get my car back ...I will make a vid once its all broken in and tuned
Old Feb 20, 2003 | 04:52 AM
T-Blaze's Avatar
Yo Miraiz... Firstly that is a heavy set up u got there... Respek!!
On the same note... I'm just about to install a Max Rev kit.. and I wanted to know what size exhaust is recommended?
I've got the MR downpipe > No cat > a silencer > then a 5Zigen Fireball Muffler... At the mo the piping is 2.25" I think... Would it be better to go for 2.5 straight through from DP > Muffler or 3"???
Cheers.
Old Feb 20, 2003 | 08:35 PM
tony1's Avatar
Default Re: apexi n1 with turbo (jerseykid609)
The turbo n1 will work good, but the N/A n1 has a pretty small inner diamter on the core of the muffler. It WILL make a difference going from the n/a to turbo...
Old Feb 20, 2003 | 09:34 PM
Full-Race Geoff's Avatar
Default Re: apexi n1 with turbo (tony1)
[Modified by FFgeoff, 1:41 AM 2/21/2003]
Old Feb 20, 2003 | 09:45 PM
Night_Minx
Guest
Posts: n/a
Zentrae:
you still have a cat?? if so, thats your biggest problem.
Old Feb 20, 2003 | 11:18 PM
nope, no cat. just the flex pipe and the rest is all N1 N/A piping. Would it be worth it for me to get the N1 turbo muffler? Get rid of the whole N/A setup(piping and muffler) and get 2.5 inch muffler shop piping with the N1 turbo muffler?
Thanks
Old Feb 21, 2003 | 03:17 AM
MiraiZ's Avatar
Old Feb 22, 2003 | 04:01 PM
mrod006's Avatar
so, would it be wise to increase the stock piping to 2.5 or 3 inches and keep the n/a muffler?
TA Performance
Northern California (Sales)
27
Aug 9, 2006 12:47 AM
BLK99VTECR
Feb 22, 2005 01:26 PM
