are b20 and b18c oil pumps the same?
i was told a b18c1 b18c5 and b20 all have the same oil pump . in fact i even read it was the same part #.can anyone confirm this for me. as far as b18c1 pumps im refering to obd2 ( with the crank sensor mount).
VTEC oil pumps are different from non-VTEC pumps. Just go w/ an ITR pump for peace of mind. You may also want to shim it & use the newer "smaller" oil filters for added pressure.
Whats so funny,isnt it true that you can run RSX filters hehee.I was wondering cause i got a prodrive gear in a gsr pump and was wondering if i can reuse it in a b20 block.I already know better to use vtec pumps in non vtec blocks i dont want to ghetto rig nothing
On the underside of the pump(side that wil face down to the pavement once installed) there is a spring-lodaed bolt. Remove this bolt, add a thin washer and re-install. Each washer should be good for an additional 5 psi or so, but I'd say and ITR pump w/ K-series filter is more than enough pressure. That's what I use.
Dr.Octagon
16
Jun 8, 2006 01:49 PM
infamousALLMTR
Nov 15, 2002 02:55 PM
