are b20 and b18c oil pumps the same?
Old Feb 19, 2003 | 03:41 PM
na200whp's Avatar
Default are b20 and b18c oil pumps the same?
i was told a b18c1 b18c5 and b20 all have the same oil pump . in fact i even read it was the same part #.can anyone confirm this for me. as far as b18c1 pumps im refering to obd2 ( with the crank sensor mount).
Old Feb 19, 2003 | 03:43 PM
Kataku2K3's Avatar
Default Re: are b20 and b18c oil pumps the same? (na185whp)
Yup all flow the same...
Old Mar 13, 2003 | 10:12 PM
J2turbo21's Avatar
Default Re: are b20 and b18c oil pumps the same? (Kataku2K3)
So will a prodrive oil pump gear fit a b20 oil pump?
Old Mar 14, 2003 | 05:11 AM
GM2000ITR's Avatar
New User
VTEC oil pumps are different from non-VTEC pumps. Just go w/ an ITR pump for peace of mind. You may also want to shim it & use the newer "smaller" oil filters for added pressure.
Old Mar 14, 2003 | 01:03 PM
J2turbo21's Avatar
Default Re: are b20 and b18c oil pumps the same? (GM2000ITR)
What do you mean by shim it?I heard you can use rsx filters and that will raise your oil pressure.
Old Mar 14, 2003 | 01:08 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: are b20 and b18c oil pumps the same? (J2turbo21)
haha
Just go w/ an ITR Pump, 90 bucks.
Old Mar 14, 2003 | 01:12 PM
J2turbo21's Avatar
Default Re: are b20 and b18c oil pumps the same? (vtecvoodoo)
Whats so funny,isnt it true that you can run RSX filters hehee.I was wondering cause i got a prodrive gear in a gsr pump and was wondering if i can reuse it in a b20 block.I already know better to use vtec pumps in non vtec blocks i dont want to ghetto rig nothing
Old Mar 14, 2003 | 01:38 PM
GM2000ITR's Avatar
New User
On the underside of the pump(side that wil face down to the pavement once installed) there is a spring-lodaed bolt. Remove this bolt, add a thin washer and re-install. Each washer should be good for an additional 5 psi or so, but I'd say and ITR pump w/ K-series filter is more than enough pressure. That's what I use.
Old Mar 14, 2003 | 01:42 PM
J2turbo21's Avatar
ohh ic,well i have really installed a oil pump before but but thats a pretty good tip.Thanks man i know for sure if its a non vtec block i will put a vtec pump on it.
Old Mar 14, 2003 | 04:21 PM
Kataku2K3's Avatar
Shimming it will generate more pressure but not more flow... As vtecvoodoo said just get an ITR pump and you'll be set...
Old Mar 14, 2003 | 04:32 PM
J2turbo21's Avatar
Done and Done.But is there any difference between the gsr pump and the type r?
Old Mar 14, 2003 | 04:41 PM
b18c-93's Avatar
New User
so i can just install a rsx filter on a gsr block , and it will add pressure
Old Mar 14, 2003 | 10:24 PM
Kataku2K3's Avatar
Default Re: are b20 and b18c oil pumps the same? (b18c-93)
Nope they are the exact same, just as all late model oil pumps... Peace
dc4-b20
Mar 10, 2009 09:07 AM
MI4$DC5
Jul 19, 2008 12:16 PM
xQB21x
Jan 24, 2007 04:39 AM
Dr.Octagon
16
Jun 8, 2006 01:49 PM
infamousALLMTR
Nov 15, 2002 02:55 PM
