Which Block is better?
Old Feb 19, 2003 | 03:32 PM
12secB18acivic's Avatar
Default Which Block is better?
A b18b w/ oversized type r piston or a stock B20 block?which one will make more power? This would be for an all motor nonvtec setup.
Old Feb 19, 2003 | 03:47 PM
Kataku2K3's Avatar
Default Re: Which Block is better? (13secB18bcivic)
Personally I would go with the B18 and the R pistons... that's just because I hate stock bottom end LS/CRVTECs... I dunno that's just me tho... Powerwise I"m sure that the CRVTEC would make more torque but fall short of the LSVTECs hp numbers... My friend has a completely stock bottom end LSVTEC with a GSR head, CTR IN cam, chipped P28 and VAFC in his EG... It's not anything special but full interior on MT 20x6x14 slicks he ran a 13.4@103... Again I would just build the LSVTEC or save to run aftermarket pistons in the B20, that's just my opinion tho... Good Luck
Old Feb 19, 2003 | 05:24 PM
Default Re: Which Block is better? (Kataku2K3)
thanks for your input Kataku2K3. anyone else? and remeber this will be for a NONVTEC set up!
Old Feb 19, 2003 | 05:53 PM
B20Monster's Avatar
i would get the b20 and put some higher compression pistons in them.. i like the low/midrange torque they produce. the b20 costs a bit more though... but worth it to me. good luck with your setup.
Old Feb 19, 2003 | 06:02 PM
Kataku2K3's Avatar
Default Re: Which Block is better? (B20Monster)
Okay my bad, I totally missed that part about you being nonVTEC.. it's all good tho... I would probably rather go with the B20 in that case... I've never seen it before but heard that a B20/EG can hang with an B18C/EG until around 3rd gear... That's pretty good tho... B20's got my vote for this.. Latez
Old Feb 19, 2003 | 08:45 PM
dfoxengr's Avatar
LS with r pistons..= higher compression/about the same torque...but while ur at it grab up a vtec head...
Old Feb 19, 2003 | 09:17 PM
10K2HVN's Avatar
Default Re: Which Block is better? (hybridvteceg)
yeah..with the whole nonVTEC thing...i would go B20Z (JDM).
Old Feb 19, 2003 | 09:21 PM
dfoxengr's Avatar
Default Re: Which Block is better? (10K2HVN)
is no b20z in japan, its b20b there, which = our B20z...
Old Feb 19, 2003 | 09:26 PM
10K2HVN's Avatar
umm..sure buddy....
Old Feb 19, 2003 | 09:27 PM
dfoxengr's Avatar
just lettin you know dont be an ***.
Old Feb 19, 2003 | 09:41 PM
10K2HVN's Avatar
im sorry, i guess ive been reading too much of someones posts (*coughThreatcon13cough*) and i guess its been rubbing off on me..NOT that i have anything against that person..its just he seems a tad bit mean in some of his post...i guess when you get over 4000 posts or so you get kinda sick of n00bs like me. Honda-Tech
Old Feb 20, 2003 | 05:20 AM
ionic_slim's Avatar
yea you sure do comeoff as one.
Old Feb 20, 2003 | 07:26 AM
dfoxengr's Avatar
thats cool man, lol i dont mind..just fukin with ya..dont worry about it...
Old Feb 20, 2003 | 11:45 AM
10K2HVN's Avatar
Default Re: Which Block is better? (tazmoe)
elaborate on that....
Old Feb 20, 2003 | 01:13 PM
so u guys would pick the stock B20 over the b18b w/ ITR pistons for more power? I thought higher comp. means more power?
Old Feb 20, 2003 | 01:48 PM
dfoxengr's Avatar
tats what im sayin, plus the itr are 25 over, since ur getting overbored ones.
Old Feb 20, 2003 | 02:04 PM
Kataku2K3's Avatar
I say B20 but that's just me... Remember "there's no replacement for displacement"... For being the fastest now I personally would just stick with the straight B20... You won't notice any difference from just being .25mm over... That's goin from ~1835cc's to ~1845... Roughly a tenth of a liter... The B20's additional 3mm bore bumps you up to ~1975cc's... so 1 and a 1/3 liters up for the overbored LS..... Again this is just my reasoning... What ITR pistons are you running USDM or JDM... The compression gains with those pistons aren't anything amazing either... They are on the low-mid compression range for an OE piston... Over them you have PR3's, P30's, and PCT's... Lower than that... just the P61, P72, and PR4's.... And with the LS head having the highest combustion chamber volume it just drops it that much more over the VTEC PR3 and P72 casts... You probably know this but the P73-A0 USDM ITR pistons will set ur C/R at ~10.3:1 and the P73-00 JDM R slugs ~10.8:1.... You'll get a little power from the 1.1-1.6:1 jump in compression but I don't know if it would match that of the B20... Just something to think about... As for the LS block with ITR pistons, if you plan to do LSVTEC down the road I would rather go with that block, unless you happened to drop aftermarket slugs and into the B20... Good Luck
Old Feb 20, 2003 | 02:14 PM
koo man b20 it is than!
Old Feb 20, 2003 | 02:17 PM
dfoxengr's Avatar
lol change ur sig then
Old Feb 20, 2003 | 02:21 PM
haha, i will after i get the b20 and see how it runs!
Old Feb 20, 2003 | 02:26 PM
dfoxengr's Avatar
sweet.
hatchattack02
18
Oct 19, 2011 12:25 PM
GSRNetics
Feb 10, 2010 09:12 PM
norcalbayboy
Aug 24, 2006 11:49 AM
NCHATCH
Acura TL, RL & ZDX
Mar 4, 2003 08:50 AM
Phoenix GSR
May 20, 2002 04:52 AM
