LS VTEC headgasket?
Old Feb 9, 2010 | 06:03 PM
GSRNetics's Avatar
Default LS VTEC headgasket?
I have a 2000 GSR Integra, with a B18a/b block that has been bored to a 2.0 liter and running B20 pistons. What headgasket would I get? Any help would be appreciated much. I tried searching a little but couldn't figure out the problem myself.
Old Feb 9, 2010 | 06:25 PM
josh-roy's Avatar
Default Re: LS VTEC headgasket?
http://cgi.ebay.ca/C4193-030-COMETIC...item5d27f35004
Bam! If your running B20 Pistons then you obviously have b20 bore, so B20 VTEC headgasket. 84mm Cometic would pull a premium before race wars. Why you would bore a b18 to run B20 pistons is beyond me.
Old Feb 10, 2010 | 12:08 AM
boostedteg1203's Avatar
Please tell me the block is sleeved! The only reason Im thinking it's not is because you're using B20 pistons instead of aftermarket ones. I'm not even sure you can bore a stock b18 block to 84mm. Anyway you would wanna use the B20 headgasket.
Old Feb 10, 2010 | 02:38 PM
josh-roy's Avatar
All b series blocks are the same... Just with different bores and what not.
Old Feb 10, 2010 | 07:24 PM
^ I think you're wrong. A B16 block is shorter than the B18 and a B20 has a larger 84mm bore but the stock sleeves are not the same as a B18. I've never heard of anyone boring a Stock B18 block over 82mm. The clyinder walls become too thin and weak.
Old Feb 10, 2010 | 07:31 PM
vwbased's Avatar
Have a nice day
Old Feb 10, 2010 | 07:48 PM
josh-roy's Avatar
Originally Posted by vwbased
No. B20's have a one piece liner assembly that is cast into the block. The rest of the B's have 4 individual sleeves cast into the block. A B18 block bored to 84 mm will have a thinner iron wall than a B20. Not good for any amount of boost.
Oh wow, i didnt know that. Thats some good info. Yeah ive also never heard of anyone going over 82 either. So why would anyone bore a b18 to rock b20 pistons, The walls would be retarded thin.
Old Feb 10, 2010 | 09:12 PM
JDMike562's Avatar
man me being a nOOb is kool. haha because i learn more and more reading these things.
Thanks honda tech friends.
JDMike562
hmt_eg
Feb 24, 2010 07:44 AM
claytonsmith
24
Feb 4, 2007 12:55 PM
NCHATCH
Acura TL, RL & ZDX
Mar 4, 2003 08:50 AM
GRIMEY.STREET.RACER
Jul 28, 2002 03:30 AM
