DA w/ B16 question
Old Feb 19, 2003 | 10:17 AM
G2 teg's Avatar
Default DA w/ B16 question
maby you guys can help, I've got a 90' ls w/ 1st gen jdm b16, the check engine light comes on some times, pretty much first drive of the day, its weird, but it only comes on once the engine has warmed to normal opperating temp., it runs fine, vtec engages correctly, not running rich, so my vtec and o2 sensors seem to be wired in fine. check engine light comes on when I begin decelerating most of the time. all fluids are topped off. Ecu wont spit me a code, any ideas???
Old Feb 19, 2003 | 10:18 AM
sgT's Avatar
sgT
Default Re: DA w/ B16 question (G2 teg)
if the check engine light is on, it should have a code. you have to read the code before shutting off the engine.
Old Feb 19, 2003 | 10:20 AM
G2 teg's Avatar
Default Re: DA w/ B16 question (sgT)
ok i'll try it with engine running, thanks
Old Feb 19, 2003 | 10:58 PM
jcda6's Avatar
When the engine light comes on, turn off the key, shut off the engine. Then turn the key back to ll position. Take a look at the LED on the ECU and refer to the Helms manual for the code.
-Jeff C.
SolidSpruce
Jul 8, 2023 03:19 PM
oilspot
Feb 24, 2009 10:16 AM
jdmazm
Apr 21, 2005 07:58 PM
hotimportcrx
Jan 15, 2005 11:38 PM
roller
Jun 13, 2004 11:57 PM
