crv pulley on jrsc
i have heard that the crv pulley is not made to spin as fast at it does with a JRSC b18c1. i know endyn makes a stepper pulley, is it 9 or 10 lbs. the crv will make about 10 lbs right? i can get a crv pulley for free but i dont want to use it if it is going to cause other parts to wear prematurely. i will be upgrading to hondata and larger injectors as well to help keep things safe. thanks.
I run jackson 8lb pulley on my blower and crv on the crank, have had no probs with exception of slight belt slip every now and then, totals 11lbs (sohc).
The Endyn stepper will give you 9 psi and will not overspin the alternator (because it is stepped). The CRV crank pulley will overspin the alternator but personally I wouldn't worry about it.
agratise
Jan 20, 2005 12:36 PM
