engine bearings
I need to get some bearing for my engine. I just got eagle rods. From what i was told is that they have number 3 rods. There is the stamp letters on my crank. On the right side where the rod are, these are these letter b,a,b,b. From my reach I think the bearings i need to get is green,yellow,green,green. Now if i got these how true will these bearing be to spec and what kind of clearance do i want for a turbo car?
thank you for taking your time
Well, if your motor is an LS or B20, then they should all be green.
When I called Eagle, they told me to use all green.
The ideal way to determine your bearing size would be to get 1 set (2 halves) of each color and plasiguage (sp?) each rod.
When I called Eagle, they told me to use all green.The ideal way to determine your bearing size would be to get 1 set (2 halves) of each color and plasiguage (sp?) each rod.
When they mark there bearing they only mark them on one half right. If its green then the bearing would be green. IS there such thin as green and yellow on the same rod.
dont ever take that advice.
pcguy760
Oct 4, 2011 10:16 PM
