Somewhat OT, Check Engine Light Question
The Del Sol's engine light is coming on. It happens when the car has been sitting overnight and is cold,t he light does not go off however if I turn the car off and back on after it has ran for a few minutes the light goes of and stays off. The car seems to run fine when it is on. How do you pull codes from the CEL? Also I was thinkg it might be my o2 sensor going bad any suggestions?
Thanks
Thanks
Here is some information on retreiveing the code. ITs for an Integra, but should be similiar
http://www.c-speedracing.com/faq/03.php
If that fails, get a Helms manual - http://www.helminc.com
search n00b
I'd say the Del Sol / EG forum but i dont konw if you'll find anything worthwhile
Thanks Stage One that page was very helpfull... of to go see what it says.
Ok I pulled the codes and it is either a 13 or a 14 and this is what that page says.
13 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor
14 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
Any one know where these are located??? I have a helms manual and it is at home. I replaced the Thermostat last week so I wounder if I bumped the sensor or unplugged it.
David Teague
[Modified by Solracer, 3:42 PM 2/18/2003]
David Teague
Don't know if this applies to a Del Slo, but the Pressure Sensor in my Integra is located in front of the passenger door area under the dash.
The IAC is on the Throttle Body - should be attached to the butterfly valve/Throttle cable area.
[Modified by Vracer111, 11:18 AM 2/18/2003]
David,
Code 14 (IAC failure) Can also set for 2 silly reasons:
1) If the coolant system has an air pocket in it. Re-bleed the system and don;t use the silly bleeder screw (I beleive on the Si's it's on the upper hose/head junction), instead, jack up the front of the car and bleed it through the cap. This way it will "burp" and all will return to normal. Air pockets can sometimes be a real pain to get out. be paitient and don't rev the motor hoping it will speed up the process, you'll know when it's done when you find a puddle of coolant under the car after the air pocket pukes it out.
1)If a valve is too tight. For some reason will only set the code at cold start though even though the valve gets tighter after warm up. If you did a valve adjustment recently, recheck all the clearances.
Good luck..and I hope it's just an air pocket..
Jeff
[edit forgot about the tight valve]
[Modified by jasyatz, 10:48 PM 2/18/2003]
Jeff
jena_blondie
18
Oct 7, 2017 07:43 PM
osbunjosh
Jul 25, 2011 08:09 PM
95GSRBOI
Sep 8, 2006 10:03 PM
