Custom 2-way downpipe installed!
Old Feb 17, 2003 | 05:28 PM
drewspeed's Avatar
Default Custom 2-way downpipe installed!
As some of you might know, I recently got a "mild" turbo kit installed. On my B18B and my restrictive exhaust (almost stock w/ ITR muffler) my turbo was only giving me 2-4psi.
I recently submitted my car to be the test guinea pig for the modification in the pictures below and was quite pleased with the results.
The reason I did this modification is because 1) I daily drive it so I wanted it to be quiet so that the law enforcement officials didn't hear me from a kilometer a way. And 2) this is the family car (4dr Integra) so it has to be somewhat civilized. I've had different exhausts in the past and they were just ear-catchers or unnecessary attention getters.
Now with this new modification you can still have a quiet car for daily driving and for the track (through the control of an electronic switch mounted inside the car) have an open header design which will maximize all the mods on your car with a free flowing type of exhaust. In this case I now hit 6-7 psi at just under 4000rpm approximately which was my goal from getting a turbo kit to begin with.
It is still in the R&D stage, so placement of this electronic valve is still pending. I have driven it for the past 3 days and am very satisfied. We have already got some input into alternative designs (making the main pipe the one with the valve and having the stock flow rerouted around, etc) but any comments/feedback welcome.
This isn't the final product but a trial mock setup. But so far so good
[Modified by drewspeed, 6:29 PM 2/17/2003]
Old Feb 17, 2003 | 07:57 PM
dfoxengr's Avatar
Default Re: Custom 2-way downpipe installed! (drewspeed)
lol ive seriously always had this idea too...
Old Feb 17, 2003 | 08:33 PM
genetsang's Avatar
interesting... glad it works... but wouldnt the exhaust pressure back up into the secondary pipe when it is it is switched off.... makes sense when you are at the track, but when daily driving... wouldnt the exhaust pressure back up into there anyways? i was just wondering by the looks of it.... you prolly know more....
good stuff
Old Feb 17, 2003 | 10:27 PM
dfoxengr's Avatar
Default Re: Custom 2-way downpipe installed! (genetsang)
basically one side is opendownpipe, the other runs into regular exhaust
Old Feb 18, 2003 | 05:32 AM
drewspeed's Avatar
Default Re: Custom 2-way downpipe installed! (hybridvteceg)
Thanks for the comments.
Yes we've discussed alterior designs and the point brought up regarding the trapped exhaust gasses when the valve is closed has been discussed.
Basically before this mod I would hit 2-4 psi in 3rd gear at WOT. With the mod and the valve CLOSED for some reason I hit 4 psi constantly. With it open 6-7 psi. So it did not look like the trapped gases were proving to be a detriment overall. But we are looking into other methods again so I'll try to keep all interested parties updated.
Old Feb 18, 2003 | 06:09 AM
genetsang's Avatar
Old Feb 18, 2003 | 09:31 AM
mrlegoman's Avatar
But since the valve would be closed just for your daily driving then the turbulance created would not really be that big of a deal, right?
Old Feb 18, 2003 | 10:11 AM
drewspeed's Avatar
Default Re: Custom 2-way downpipe installed! (mrlegoman)
That is correct. But to make it more efficient while it is closed, some people have suggested to route it differently. Like I said, with the way it is now, with the valve closed it runs slightly better than it did when I didn't have the valve although that could only be proven by getting some dyno numbers.
Old Feb 18, 2003 | 10:15 AM
qtiger's Avatar
Exhaust cutouts have been on the market for years, you can buy one at most major racing stores.
Old Feb 18, 2003 | 02:37 PM
mrlegoman's Avatar
Default Re: Custom 2-way downpipe installed! (qtiger)
Yeah, I've seen the el-cheapo ones with the cable running up through the floor board. But theres something about a custom setup that adds that touch of class.
(BTW: Which can be crushed very quickly if you have 20 inch rims and a triple decker wing )
Old Feb 18, 2003 | 03:44 PM
TurbothisLS's Avatar
i would do it so that it was a y pipe: one to the stock exhaust one to open downpipe. When closed, the exhaust would just go to the stock exhaust setup, when open it could go both ways, out the stock exhaust and out the open dump
this way you wouldn't have that nasty bend in the middle of the dp
Old Feb 18, 2003 | 04:16 PM
10K2HVN's Avatar
you talkin about this thing???
Old Feb 18, 2003 | 05:51 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
wow...that's pretty neat. i have also had this idea for my sleeper. i like and have thought of your approach. if i used a throttle plate, i would have hooked it up to a wastegate actuator so it would open up the more i boosted. since that is my case, if i built a system like this, i would use a wastegate and routed dumptube. i like how yours is vouluntary.
[Modified by not so civic, 2:52 AM 2/19/2003]
Old Feb 18, 2003 | 07:07 PM
Eee Pee's Avatar
Default Re: Custom 2-way downpipe installed! (not so civic)
Why not use one of these from Jeg's?
Old Feb 18, 2003 | 07:12 PM
tegasaurus's Avatar
Default Re: Custom 2-way downpipe installed! (Eee Pee)
u can... but u haev to get under the car to open it up or close it
Old Feb 18, 2003 | 07:19 PM
91DA9's Avatar
Default Re: Custom 2-way downpipe installed! (tegasaurus)
I saw this on some truck show on TNN. They had the electronic openers and everything. Of course they were using a 455 BB.
Old Feb 18, 2003 | 08:09 PM
Eee Pee's Avatar
Default Re: Custom 2-way downpipe installed! (94IntegraGSR-OVR)
Couldn't you bolt the remote opener
onto the end of the Jeg's piece?
Old Feb 18, 2003 | 08:55 PM
untuned's Avatar
damn that is a work of art..
can't wait to see the finished product
Old Feb 19, 2003 | 06:15 AM
drewspeed's Avatar
Default Re: Custom 2-way downpipe installed! (untuned)
Thanks for the compliments. The e-cutout was picked up from quicktimeperformance. All welds done by Ultimate Racing.
It does look like its going back into the shop for some design alterations as you will kind of notice in the first pic that its hard to access the oil filter now You can still reach it but makes it harder to access that's all.
Old Feb 19, 2003 | 06:22 AM
ASHY-ELBOW's Avatar
onto the end of the Jeg's piece?"
yes thats what i am doing total cost is around $130
i am using this http://www.mccordcg.com/mpp/mpp.htm
with the picture of the jegs one above
it says right one there site that it will bolt right up to the jegs cutout
Old Feb 20, 2003 | 05:44 PM
JSJ EG6's Avatar
where can i get one of these?????
Old Feb 20, 2003 | 06:48 PM
ASHY-ELBOW's Avatar
Default Re: Custom 2-way downpipe installed! (TEAM JSJ)
www.jegs.com under exhuast cutouts
Old Feb 20, 2003 | 06:53 PM
Norcalstoppy's Avatar
Default Re: Custom 2-way downpipe installed! (D-BOE)
why not go all out and get this....this is awesome. I'm getting one for myself sooner or later.
Jay Kim
Old Feb 20, 2003 | 07:05 PM
. o 69 o .'s Avatar
Default Re: Custom 2-way downpipe installed! (AllMotorMonster+)
whats the difference between this one and the other ones?
Astig
Mar 14, 2007 03:01 PM
spooncivic1
May 17, 2005 09:16 AM
TheCiscoKid
Sep 28, 2003 05:13 PM
DUCK COMMANDER
Sep 13, 2002 10:52 PM
KC GSR
Aug 8, 2002 10:36 PM
