positive boost at idle w/ bosot timing retard from hondata?
Old Feb 16, 2003 | 10:47 PM
pissedoffsol's Avatar
25 Year Member
Default positive boost at idle w/ bosot timing retard from hondata?
hey guys-
I was talking with scott from http://www.tripledigitmotorsports.com tonight about our cars . . . balh blah . . we got to talking about axles for launching and so forth. I amde the statement that I'm not too woriied about them, as I'm going to have about 50 hp when i launch due to crazy lag of the t4 60-1 I will be running. He mentioned that he was reading up on the hondata boost timing retard and that by using this feature, a honda will actually create positive boost with no engine load.
I disagreed. My understanding of all this is that with a MAP-based car, it is impossible to build positive boost (ok, maybe 1 psi) with no load. On a MAF-based car however, it is possible, as it is based of of flow, and not load.
This isn't a pissing match of who is right/wrong, just trying to get some facts on this so we can both better our cars/setups. Any advice would be appreciated.
-Brian
[Modified by delvtecsol, 2:48 AM 2/17/2003]
Old Feb 17, 2003 | 02:40 AM
UberTeg's Avatar
Default Re: positive boost at idle w/ bosot timing retard from hondata? (delvtecsol)
first of all, you are a tool if u think a MAF car can spool a turbo better than a MAP based car. That said, you can build boost with drasticly retarded timing, because u are pretty much ignitign the fuel mixture as its leaving the ports. Lots of heat and expantion to feed the urbo energy
Old Feb 17, 2003 | 04:59 AM
ekb18c's Avatar
I'm going to be coming out of the hole with 14psi of boost.
InTeGrA B18b1
Dec 12, 2004 06:06 PM
pipes
Feb 20, 2004 09:19 AM
dominate9
Dec 22, 2003 09:14 PM
willyboyK20
Oct 30, 2002 09:50 PM
hybrid901
Sep 11, 2002 05:33 PM
