What would you rather squitr w/ cold water, the intercooler or intake manifold.
Old Feb 14, 2003 | 01:42 PM
BoostedGSRBubble's Avatar
Default What would you rather squitr w/ cold water, the intercooler or intake manifold.
My cf hood has on holes for windshield washer squirters. So i was going to use the system to either spray ice water on the intake mani or the intercooler (like the sti).
Which, if either, would be benifical? Thanks.
Old Feb 14, 2003 | 02:11 PM
Kevin's Avatar
Default Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (trustsi)
Mitsubishi evos have water squirters on the intercooler from the factory. Im sure you would see a much bigger improvement if you put it on the intercooler. Put one squirter on each side and have them spray towards each other so the mist covers the entire face of the intercooler. It might actually work pretty well Just dont do it at the drag strip
[Modified by 5speedv6, 11:11 PM 2/14/2003]
Old Feb 14, 2003 | 02:18 PM
Default Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (5speedv6)
yea i was leaning toward the intercooler. I would do it at the drag strip but in the burn out area. Its wet there anyways.
Old Feb 14, 2003 | 02:30 PM
WONG FRIED RICE's Avatar
deffinately intercooler. They actually make a intercooler misting kit. For got what company tho.
Old Mar 20, 2003 | 08:03 AM
GZERO's Avatar
Can u explain why you say this? is it because you can get your tires wet?
Does anyone have a link to this or any other water injection system be on the outside of the intercooler or on the inside of the intake?
Old Mar 20, 2003 | 09:32 AM
CRX SiR T's Avatar
Default Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (GZERO)
Can u explain why you say this? is it because you can get your tires wet??
leaking any type of fluid while on the track is illegal. thats why catchcans are mandatory. It could cause someone to go out of control, ect.
Old Mar 20, 2003 | 09:47 AM
GZERO's Avatar
Default Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (CRX SiR T)
but the question would be, wouldn't the water evaporate when it hits the intercooler leaving no trace of water at all on the floor?
Old Mar 20, 2003 | 09:56 AM
senpai's Avatar
Think about it ... when you turn on your windshield wipers, do you see how much water comes out? That will not evaporate quickly
Old Mar 20, 2003 | 10:06 AM
shadowdawn's Avatar
Default Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (maztur)
Just rig up your own nitrous purge to spray on your intercooler, or get the NX bar if you REALLY want to cool that thing down. Warm water isen't gonna do that much (since that "iced water" you put under the hood will stay "iced" for about 10 minutes).
Old Mar 20, 2003 | 11:10 AM
LSiTurbo's Avatar
Default Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (JDMB16ACRX)
Pivot makes a water squirter kit for IC
Old Mar 20, 2003 | 11:19 AM
GZERO's Avatar
Valid point, but the water sprays should leave a "mist" of water, not the squirt that the normal windshield squirters throw, right? so that "mist" should distribute itself on the intercooler evenly, that way evaporating itself, or well, most of it.
[Modified by GZERO, 3:21 PM 3/20/2003]
Old Mar 20, 2003 | 12:00 PM
rice4life's Avatar
you should use a mister nozzle(like the one they use at a plant nursery), not your windshield washer nozzle. and you should put it in front of the intercooler, not the back because the air will just blow the mist back into the intercooler.
Old Mar 20, 2003 | 12:02 PM
TurbothisLS's Avatar
you could get those improved water sprayers from a local performance shop.
they mist instead of spray
isquishplatano
Jul 8, 2008 10:57 AM
mamaboy
Aug 10, 2004 07:57 PM
-=TWITCH=-
Dec 3, 2002 10:25 PM
Aeka GSR
Jun 14, 2002 07:26 AM
