What would you rather squitr w/ cold water, the intercooler or intake manifold.
My cf hood has on holes for windshield washer squirters. So i was going to use the system to either spray ice water on the intake mani or the intercooler (like the sti).
Which, if either, would be benifical? Thanks.
Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (trustsi)
Mitsubishi evos have water squirters on the intercooler from the factory. Im sure you would see a much bigger improvement if you put it on the intercooler. Put one squirter on each side and have them spray towards each other so the mist covers the entire face of the intercooler. It might actually work pretty well Just dont do it at the drag strip
[Modified by 5speedv6, 11:11 PM 2/14/2003]
Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (5speedv6)
yea i was leaning toward the intercooler. I would do it at the drag strip but in the burn out area. Its wet there anyways.
deffinately intercooler. They actually make a intercooler misting kit. For got what company tho.
Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (GZERO)
Can u explain why you say this? is it because you can get your tires wet??
Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (CRX SiR T)
but the question would be, wouldn't the water evaporate when it hits the intercooler leaving no trace of water at all on the floor?
Re: What would you rather squitr w/ cold water, the intercooler or intake manifold. (maztur)
Just rig up your own nitrous purge to spray on your intercooler, or get the NX bar if you REALLY want to cool that thing down. Warm water isen't gonna do that much (since that "iced water" you put under the hood will stay "iced" for about 10 minutes).
Think about it ... when you turn on your windshield wipers, do you see how much water comes out? That will not evaporate quickly
[Modified by GZERO, 3:21 PM 3/20/2003]
you should use a mister nozzle(like the one they use at a plant nursery), not your windshield washer nozzle. and you should put it in front of the intercooler, not the back because the air will just blow the mist back into the intercooler.
you could get those improved water sprayers from a local performance shop.
they mist instead of spray
Sinner
06-15-2004 08:09 AM
