ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks!
Old Feb 13, 2003 | 08:29 PM
Licensed2Spool's Avatar
Default ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks!
If you drive a turbo'd B18B, please post your 1/4 mile numbers, your turbo setup, type of tranny ect... Thanks!!!!
Old Feb 13, 2003 | 11:17 PM
*Boostwerks*'s Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (Licensed2Spool)
.....sorry to say, but
search.
Old Feb 14, 2003 | 06:09 AM
Tinker219's Avatar
this is for the 1/8th:
9.04 @ 81
1.95 60ft on street tires
straight B18B swap.
little under 5psi in a 6th gen coupe.
I think my 60 ft was so good because the car was on its bumpstops in the rear, giving me the 1000lb springs in the rear effect...i will be doing this again in the future to save cash
Old Feb 14, 2003 | 08:12 AM
Therumblingteg's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (Tinker219)
13.3
12psi
stock ls
Old Feb 14, 2003 | 08:29 AM
b18tdelsol's Avatar
13.7..7psi.. in a delsol.
Old Feb 14, 2003 | 08:53 AM
integranator's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (b18tdelsol)
What turbo set-up is everyone running??
Old Feb 14, 2003 | 09:05 AM
Mase's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (integranator)
my own
Old Feb 14, 2003 | 10:31 AM
st00pid's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (Mase)
my gf's car:
stock LS swap
custom T3 T04B turbo system
Hondata
440cc injectors
block guard
JG 1001 cams
NX nitrous system
11.6 @ 123mph with 20 psi and nitrous jetted to 50hp on 118 octane
12.1 @ 115 with 20 psi on 93 octane no nitrous
I just finished up another turbo LS setup that is built Ill post numbers when we get them.
jason
Old Feb 14, 2003 | 10:34 AM
avividmemory's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (st00pid)
Hey st00pid, are those internals stock not counting the blockguard?
Old Feb 14, 2003 | 10:38 AM
giooooo's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (SpoolinLS)
check out the january or feb issue of sport compact car and ook for a red hatch i think thats what hes talking about correct me if im wrong...
Old Feb 14, 2003 | 10:44 AM
Smashback's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (Giovannie)
Yeah that's his (her) car. I think st00pid always runs stock internals with a block guard. Trying to prove a point or something
Old Feb 14, 2003 | 11:16 AM
shadowdawn's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (Hatchblack)
14.4 @ 98.8 mph
Stock engine and tranny
Rev hard stage 2c kit
AFC hack setup + 440rc injectors
Thats the jist, hit the sig if you need more info.
Old Feb 14, 2003 | 11:19 AM
bretx0r's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (shadowdawn)
14.4 @ 98.8 mph
goes to show how much honda auto trannys suck
Old Feb 14, 2003 | 11:24 AM
Evil DOHC's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (bretx0r)
Best Friends Ride in 2001:
B18B 1997 integra ls body. 2650 lbs with driver. 24.5x8x13 slicks.
1.71 60ft
11.8 @ 118 mph
14 - 15 psi of boost on a turbonetics t3/t4b. No hp numbers just ran the track at 100 degree nj summer weather. Car was tuned by me via vafc and some rc injectors, very simple setup that ran well for over two years before he sold the car.
EVIL
[Modified by Evil GS-R, 12:24 PM 2/14/2003]
Old Feb 14, 2003 | 11:45 AM
DIRep972's Avatar
Smarter than you
revhard kit
thermal 3"
hondata/550's
bfg drag radials
ACT HD/SS clutch
stock LS motor/stock LS tranny
dyno'd 274/237 on 12psi
ran 13.0 @ 110 w/ 2750lbs(over wieght by 100lbs that night an granny shifting my broken tranny)
Old Feb 14, 2003 | 12:01 PM
Smashback's Avatar
Default Re: ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks! (DIRep)
Extra 100 lbs? What happened...you kill your girl and go to the races before you had a chance to dump her?
Old Feb 14, 2003 | 12:06 PM
DIRep972's Avatar
Smarter than you
no I usally wiegh in at 2650. cause in race trim i have 1/4 tank, no spare, an no extra junk. basically I went down there spur of the moment that night an had a full tank an all my tools, all my school stuff an the car was a pig on the scales.
92lstcvc
Mar 22, 2006 12:37 PM
ernald711
Sep 4, 2003 03:53 PM
94b18b1
Jul 8, 2003 01:58 PM
HuskerHybrid
May 22, 2002 11:17 AM
