Wastegate Install Question
Old Feb 12, 2003 | 04:45 PM
Fatty_1775's Avatar
Default Wastegate Install Question
I read that the top part of the wastgate (delta gate) is for a boost controller and the side goes to a vaccuum source. The person who installed this for me says that he can not adjust the wastegate and it is stuck. Is it because it is connected wrong (top and side)? Any opinions would be appreciated. Revhard Stage 2 on a B16. I will try and attach a pic.
[Modified by Autobot_Killer, 1:46 AM 2/13/2003]
Old Feb 12, 2003 | 04:48 PM
zojirushi's Avatar
Default Re: Wastegate Install Question (Autobot_Killer)
if u don't have a boost controller, nothing connects to the top port of the deltagate wastegate
Old Feb 12, 2003 | 04:49 PM
Fatty_1775's Avatar
Default Re: Wastegate Install Question (zojirushi)
So I guess the connection is backwards? It looks like the top is connected to the intake manifold. Also, how can you tell if the waste gate is open at idle?
Old Feb 12, 2003 | 05:02 PM
Foozball26's Avatar
if the wastegate is open at idle you'll hear it lol
it will sound like you have open exhaust.
put the hose from the intake manifold onto the bottom port and be done.
[Modified by foozball-26, 8:02 PM 2/12/2003]
Old Feb 12, 2003 | 05:04 PM
Fatty_1775's Avatar
Default Re: Wastegate Install Question (foozball-26)
I wonder where the bottom is connected to? Yeah, when I rev the engine, I hear a weird throaty sound. I guess that's the sound you are talking about!!! lol
Old Feb 12, 2003 | 05:09 PM
Foozball26's Avatar
that would be it
GRT's Avatar
GRT
take the hose off the top and plug it @ the mainfold. if you want more boost just sink the screw but it should only go as high as the number on the sticker but dont go crazy I've seen a 10 psi spring go 15psi
Old Feb 12, 2003 | 05:25 PM
B20-T's Avatar
Default Re: Wastegate Install Question (GRT)
So, iF i dont have a boost controller nothing connect to the top?do i just plug the top off with a rubber cap?and as the side of the wastegate connect to my charge pipe?plmk thanks
SIXTYdashONE's Avatar
HT's Biggest Loser
yeah, u only need to connect the side (not top) to the intake mani, the top is just for boost controller...
Old Feb 12, 2003 | 05:32 PM
Fatty_1775's Avatar
Default Re: Wastegate Install Question (SIXTYdashONE)
What do you plug it with? Also, what happens if you drive and the wastegate remains open?
[Modified by Autobot_Killer, 2:42 AM 2/13/2003]
Old Feb 12, 2003 | 07:35 PM
Foozball26's Avatar
you leave the top open no need to plug. If the wastegate remains open you'll wont build **** for boost for a long while into the rpm band.
the wastegate will open when you reach the desired boost level.
[Modified by foozball-26, 10:36 PM 2/12/2003]
Old Feb 12, 2003 | 08:14 PM
Fatty_1775's Avatar
Well, when I drove it, with the way it is set up, it went up to 12 psi!!! The sticker on the wastegate said 7 - 9.
Old Feb 12, 2003 | 08:21 PM
B20-T's Avatar
ok ..i left the top open and side i hook up to my charge pipe ..is that how it suppose to go?
Old Feb 12, 2003 | 08:24 PM
B20-T's Avatar
Default Re: Wastegate Install Question (B20TURB0)
from the side of the w/g the pipe i connect to is ..the pipe that connect to my turbo
TurbothisLS's Avatar
boost cannnot be adjusted on the deltagate
it is regulated by a spring
you would have to switch the spring out
but the wastegate vacuum ports should be:
top left open atmosphere if no boost controller
side goes to turbo like shown in the picture
[Modified by TurbothisLS, 11:24 PM 2/12/2003]
B20-T's Avatar
that pipe that lead into the intercooler
Old Feb 12, 2003 | 08:32 PM
Fatty_1775's Avatar
Isnt the boost adjustable on the deltagate by a screw????
Old Feb 12, 2003 | 08:37 PM
B20-T's Avatar
any1 have a 5,6,or 7 psi boost spring laying around..ill buy one ..i am stuck with a 10psi spring..any1 have one please email me at alexngo47@attbi.com or pm ..thanks
Old Feb 13, 2003 | 09:08 AM
Fatty_1775's Avatar
So the way it was set up, both the top and side connected, is that why i was boosting at 12 instead of 7 - 9 psi?
Old Feb 13, 2003 | 09:14 AM
racerxadam's Avatar
yes, disconnect the hose from the top port on the wastegate and either remove the hose and cap the tee that it is coming from, or plug the hose. I would cap the tee.
B20-T's Avatar
yes its because u have both connected..i use to run it like that..but now i took the top off and just connect the side to my turbo.it now run at what ever spring u hav ein htere
Old Feb 13, 2003 | 05:01 PM
Fatty_1775's Avatar
So how does it have more boost than what is stated if both are connected?
Old Feb 13, 2003 | 05:08 PM
inspyral's Avatar
If you have a boost/vac reference connected to both ports, when you go into boost, the two signals will cancel each other out, keeping your wastegate from opening.
The top port of my d/g is connected to my EBC, the side port is connected to my compressor housing:
Old Feb 13, 2003 | 05:42 PM
93H22ACX's Avatar
Default Re: Wastegate Install Question (inspyral)
the side of my delta gate is connected to the intake manifold and the top part is connected to my TVVC manual boost controller. The side of the turbo is also connected to my manual boost controller.
eglslsd
Jul 13, 2007 07:59 AM
srg
Jul 20, 2006 09:35 AM
99B16Si
Mar 4, 2006 07:45 PM
s2kkk
Jun 12, 2005 12:39 PM
MRSI00
Jan 12, 2003 09:13 PM
