My horn doesn't go beep beep no more.....
Old Feb 11, 2003 | 08:01 PM
hardboiled egz's Avatar
Default My horn doesn't go beep beep no more.....
What should be the best way to fix this problem...I need some (Help Tip) information peoples.
peace out
Old Feb 11, 2003 | 08:05 PM
.Beaver's Avatar
Bloody Beaver
Default Re: My horn doesn't go beep beep no more..... (hardboiled egz)
while the title of your thread was sort of humorous, it really doesn't help. Does it make any sound what so ever, or completely dead?
Old Feb 11, 2003 | 08:09 PM
iamdoughnut's Avatar
Default Re: My horn doesn't go beep beep no more..... (93 MR EJ1)
Check the fuse box.
Old Feb 11, 2003 | 08:49 PM
2080EK's Avatar
New User
Default Re: My horn doesn't go beep beep no more..... (iamdoughnut)
Check the fuse box.
OR also check the horn itself under the hood. could be blocked or full of junk. IE Mud Etc...
Old Feb 11, 2003 | 08:51 PM
TurboBumblBee's Avatar
Default Re: My horn doesn't go beep beep no more..... (ikonEK)
check the wires.. just a little thought, but someone wanted to try to break into your car and they cut the horn wires behind the front bumper.. hope its not that cause you are a target now.. good luck fixin it..
Old Feb 12, 2003 | 06:08 AM
CsabaH's Avatar
I know my horn didn't work when it was frozen last week, it sounded pretty retarded actually...lol, but judging by what your profile says you don't have a snow problem. Check for corosion on the wires where your horn gets it's signal.
Old Feb 12, 2003 | 06:27 AM
.jacob's Avatar
Default Re: My horn doesn't go beep beep no more..... (CsabaH)
Mine doesn't work either. I played around with the connections from the steering column and got it to work for about 5 seconds.
-Jake
Old Feb 12, 2003 | 06:40 AM
SiR831's Avatar
Default Re: My horn doesn't go beep beep no more..... (Chiller514)
You can start off by checking fuses. Or you can disconnect the horn connector and use a test light (across the connector) and have someone press the horn button. If the test light lights then you verify that the circuit is good and the horn is bad.
Old Feb 12, 2003 | 06:20 PM
Default Re: My horn doesn't go beep beep no more..... (SiR831)
thanks for the replies everyone....The result was the wires....they were cut....mudderfudderdamnitz....someone was planning to steal my "egg.."
94 IntegraLS
Sep 17, 2007 05:29 PM
jdm_gal25
Apr 14, 2007 09:00 AM
d1nki
14
Sep 7, 2006 07:07 PM
cloudx71
Jul 11, 2005 07:31 PM
FBP Si 2000
14
Dec 23, 2001 07:54 PM
