My horn doesn't go beep beep no more.....
What should be the best way to fix this problem...I need some (Help Tip) information peoples.
peace out
peace out
Re: My horn doesn't go beep beep no more..... (hardboiled egz)
while the title of your thread was sort of humorous, it really doesn't help. Does it make any sound what so ever, or completely dead?
New User
Re: My horn doesn't go beep beep no more..... (iamdoughnut)
Check the fuse box.
Re: My horn doesn't go beep beep no more..... (ikonEK)
check the wires.. just a little thought, but someone wanted to try to break into your car and they cut the horn wires behind the front bumper.. hope its not that cause you are a target now.. good luck fixin it..
I know my horn didn't work when it was frozen last week, it sounded pretty retarded actually...lol, but judging by what your profile says you don't have a snow problem. Check for corosion on the wires where your horn gets it's signal.
Re: My horn doesn't go beep beep no more..... (CsabaH)
Mine doesn't work either. I played around with the connections from the steering column and got it to work for about 5 seconds.
-Jake
-Jake
Re: My horn doesn't go beep beep no more..... (Chiller514)
You can start off by checking fuses. Or you can disconnect the horn connector and use a test light (across the connector) and have someone press the horn button. If the test light lights then you verify that the circuit is good and the horn is bad.
Re: My horn doesn't go beep beep no more..... (SiR831)
thanks for the replies everyone....The result was the wires....they were cut....mudderfudderdamnitz....someone was planning to steal my "egg.."
FBP Si 2000
14
12-23-2001 07:54 PM
